You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
ok, i just bought a 93 lightning with very low miles. my first question is does anyone know what offset i would need for a set of 17x8 wheels (i believe that is stock size). Also i've noticed that the speedometer jumps around between 60 and 75. how do i fix this? finally the truck has been lowerd about 2" in front and 3" in back and since the drop was done the front tank has not worked properly. i've checked to see if there was a recall on my truck and according to the dealership there isn' a recall for this problem. any ideas on what it could be or what i can do to fix it?
Measure the distance from the rotor to the nearest object in the wheelbay. rotate the wheel lock to lock and measure again. The distance that you get is the maximum backspacing.
The speedo jumping might be the gear in the tranny, if it was an old truck. It being a new truck I'm not sure.
what are the symptoms with the tank not working? Do the gauges work and not any fuel flow? no fuel guages? I'd check the connections, and make sure the fuel pump is hooked up. Might have been something that the guys doing the lowering forgot to hook back up.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
