ETHANOL & GAS MIX? - Ford Truck Enthusiasts Forums
ETHANOL & GAS MIX?
Old 04-18-2006, 12:02 AM
sharpshooter sharpshooter is offline
sharpshooter is starting off with a positive reputation.
ETHANOL & GAS MIX?
This may be a stupid question but here goes nothing:
I just purchased a brand new 2006 F-150 Lariat Supercrew with the Flex Fuel 5.4L V8. I was told that BP sells ethanol because around here it's hard to find. I was wondering 1st though is it safe to mix gas and ethanol or should I run my tank dry then fill it up with ethanol? How much cheaper is the ethanol? Where can I get ethanol besides BP? I never let my tank get below 1/4 of a tank so I was wondering if I should run it dry then fill it up and if I did would I run into any problems? I've heard nothing but good things about the flex fuel and even had it recommended by one of the Ford dealers on this website but I do not know anyone personally who has used the advantages of the flex fuel. Any feedback would be most appreciated guys. Thanks.
Old 04-18-2006, 08:55 AM
whowey whowey is offline
whowey is starting off with a positive reputation.
No need to run it dry first.
So far only vehicles that ran quite awhile on regular, and then switched to the E85 blend have had problems. Because the E85 will remove some of the varnish and gunk that is left behind by non-ethanol fuels.
Price differences vary greatly by region. Here in Illinois, it has been averaging 50 -75 cents per gallon cheaper. BUT, we have the raw materials, and the production plants close by.
Old 04-18-2006, 12:18 PM
CA55F100 CA55F100 is offline
CA55F100 is starting off with a positive reputation.
Your owners manual will outline that. For example, my Dodge Caravan FFV says do it under 1/4 of a tank. My bosses FFV Chevy 1500 says do it before 1/4 of a tank. I have done it both ways in my van with no problems.
Old 04-18-2006, 09:32 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Thread moved to Alternative Fuels forum.
-Matt
Old 04-28-2006, 10:15 PM
Weevil Weevil is offline
Weevil is new and has a neutral reputation at this point.
Smile Don't worry about it
I can't see how it can make any difference when you fill up your tank. "Ethanol" is already a mix of gas and alcohol. If your F-150 runs on 100% gas and 90% gas (which is what they sell as "ethanol"), it should run on any mix in between. Even if the new Lariat is able to use E85 which is 15% gasoline, then it will run on any mix in between.
Old 04-29-2006, 01:30 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
There is a sensor in the fuel system on a flex fuel vehicle that identifies the fuel mixture for the computer. A flex fuel vehicle can run on anything from 0% to 85% ethanol. Your mileage will drop a tad with ethanol in the mix but that is what some of the price differential is supposed to make up for. Call around and see if you can find any more stations with E85.
Ethanol, or ethyl alcohol, or grain alcohol, is a two carbon chain alcohol that is mixed in drinks or denatured by mixing with toluene or other chemicals for industrial or medical uses. E85 or gasohol are the terms used for automotive fuels containing 85 or 10% alcohol respectively.
Old 04-29-2006, 12:32 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
My dad just bought a 2006 F150 XLT Super Crew with the same motor. It gets the same mileage on E85 that it does on regular gasoline, 15.5MPG, assuming the same driving conditions. The water's warm, jump on in!
See the following site for information about E85 and refueling locations:
http://www.e85fuel.com/
Old 04-30-2006, 02:20 AM
Torque1st's Avatar
Posting Legend
Have his truck checked, mileage will always be lower with E85 but the fuel cost will help offset it. According to government figures the fuel and operational cost with E85 is also higher.
Check out this thread:
http://www.ford-trucks.com/forums/sh...d.php?t=484181
Old 04-30-2006, 01:11 PM
With only 1800 miles on the truck, I doubt there's anything wrong with it. I drove the trips we went on. Miles / gallons. Runs and drives exactly the same on E85 as it does on gasoline.
I think the variable valve timing and 9.8:1 compression ratio has a lot to do with it.
I almost didn't say anything because I knew you guys would never believe it.
Now to be fair, at the place where someone I know works, they have a fleet of 1999 flex fuel Rangers. He says those get 20mpg on gasoline and 12mpg on E85. Those lack the higher compression ratio and variable valve timing of the newer motors.
Old 05-03-2006, 09:26 PM
We have more data:
We filled up again today. This tank of E85 was run about 30% highway, 70% in town short trips. This time it was 12.7mpg. Since most of this truck's previous mileage has been on the highway, we dont have a gasoline mileage number for in town driving to compare that to. When we get that, I'll report back. My current theory is that E85 might reduce mileage on in-town short trips. We shall see.
Old 05-03-2006, 10:36 PM
Smile Go For It !
Quote:
Originally Posted by rusty70f100
We have more data:
I tried E85 a couple times last summer when we lived in MN. Now live in MO and don't think it's available here. I'd like to try it again if the price was right. Try it in different ratios with regular gasoline.
E85, so the experts all say, has less energy and hence you will get less MPG.
I didn't do an accurate check but I think the MPG was somewhat less. Our Dodge Caravan seemed to have plenty power and "seat of the pants" could't tell the difference when burning approx 50% E85 and 50% gasahol. (10% ethanol) Some vehicles may burn the E85 more efficiently.
Whatever, it's interesting to experiment with it and I sure wouldn't discourage anyone from doing so. Keep everyone informed.
Old 05-05-2006, 10:32 AM
2000Ford2000's Avatar
2000Ford2000 2000Ford2000 is offline
2000Ford2000 is starting off with a positive reputation.
Even Ford will tell you that you will get less mpg with E85. If you get the same with E85 and 'E10" then you've miscalculated your mileage. Furthermore, an acurate mpg can only be seen after 5 or more fill-ups as you can have up to a 2 gallon difference in what a 'full' tank is depending on whose filling it up and what the outside temperature is.
Old 05-05-2006, 10:44 AM
You will see a greater reduction in mileage in town than on the highway, as one would expect. If you aren't seeing a difference, I would recalculate.
I love E85 and am willing to admit the difference in mileage.
Old 05-05-2006, 12:59 PM
Look, I dont care one bit if anyone here believes me or not. The figures I stated here are true. The E85 mileage reading was taken on the second full tank of E85. Same station, same parking angle, let it click itself off.
Old 05-05-2006, 02:51 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Adding in. E85 is not gas alchohol mix.
Its Gas and Ethanol mix, and ethanol is not alchohol.
Its fuel made from corn.
Most stations already mix in 10 to 15 percent ethanol in their fuel.
Which gasoline? abeagle 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 01-22-2014 06:26 PM
Ethanol or 100% gas that is the question mgrobe1 1999 to 2016 Super Duty 20 04-12-2013 09:29 AM
Gas with Ethanol Added xjcamaro89 2004 - 2008 F150 39 01-02-2009 11:53 PM
How much does ethanol lower MPG? stu37d General Automotive Discussion 10 05-23-2007 08:23 AM
Gas with 10% Ethanol Tomcat7742 General Automotive Discussion 33 04-25-2006 02:54 PM
Tags
2001, bp, canada, e85, ethanol, f150, ford, gas, gasohol, good, mix, mixed, ontario, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
