You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 97 expedition with a 4.6.In 1st gear the engine will pull without any problems.In 2nd gear it starts to have a drop off right around 3100 rpm.if you give it more gas it will stumblue through to about 3600 and then seem to pick up power like normal.While crusing on the highway in OD and then making a pass the truck will down shift and when it hits about 3100 the tack will sweep past 3100-3200-3300 with loss of power fall down a little and try again to climb in rpm.With the foot hard on the gass it will break through the rpm at about 3600-3700 and seem to come to regular power and keep pullin till 6000.Crusing at high speed without the OD on and gettin to about 3200 while staying on the gas the power falls off.I replaced the plugs .wires.and even tried to swap out the coil packs.Same problem before and after tuneup.The service engine light has not come on at all,and does not show any codes.Been to 3 ford dealers and they could not tell me what is causing the problem and some of them have told me not to worry.I am a good mechanic when it comes to cars.and been fightinng with this problem for a while.any help would be helpfull.Thanks Mark
We are happy you have chosen the best source for Fords.
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Did you check the fuel pressure while it does this?
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
I checked the fuel pressure today.31 psi with the engine at idle.40 psi with the vacume pulled off the fuel pressure valve.engine off 40 psi after 5 minutes.any ford guys in the hartford area.thanks mark
Pretty good, but I was really asking if you checked the fuel pressure while it's doing this "no power at 3000RPM" thing
__________________
I forget what it's called but on the 01s there is a valve under the intake that opens
around 3000 rpms to blend the intake pulses. you may check to see if it applies to yours.
I believe that only the V-6 and 4V Cobra/Mark VIII/Navagator engines have the split port intakes.
Uh, what he said.
And 3-valve 5.4's and V10's.
And the 3-valve 4.6L Mustang.
__________________
I found the valve I was thinking of it's the Intake Manifold Tuning valve.
According to the 97 to 02 Haynes it's in the V6 & V8s and it opens above
3000 rpms to blend the intake pulses for a better air/fuel intake charge.
It may not apply to the OPs problem but the RPM range is about right.
Take Care
Bill F
This is actually the first time I've heard of it, but you're right, it does exist...
And it seems to be the right RPM range too...
Something to look at.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
