Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2006, 11:58 PM
zman764 is starting off with a positive reputation.
Really Dumb Question
What exactly is a flathead engine? Believe it or not I am mechanically inclined and understand how an engine works and alot about them.
__________________
'97 4x4 4.6 191k miles
March 20th 2006
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-17-2006, 01:29 AM
51ford fan's Avatar
51ford fan is starting off with a positive reputation.
Good question not a dumb one, go to the Flathead Engine sites at the links below. If you know how the overhead engine is built with the valves in the head you will notice in the Flathead engine drawings in the links below how they are in the block on that design.
http://www.vanpeltsales.com/FH_web/flathead_home.htm
http://www.vanpeltsales.com/FH_web/f...itelinkspg.htm
http://www.btc-bci.com/~billben/flathead.htm
Hope this helps
Rod 51F1
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #3 (permalink)
Old 04-17-2006, 01:30 AM
mtflat is gaining momentum as a positive member of FTE.mtflat is gaining momentum as a positive member of FTE.
They weren't really called flatheads until the OHV engine became common in the 50's. Then the term popped up and the rest is history. There are no dumb questions.
The valves are in the block beside the pistons. The head is only a waterjacket with sparkplugs and compression chambers. And I guess technically the heads also serve as valve covers of sorts.
Check out this website - it covers a good bit.
edit: evening Rod, I see you've got it covered! - Tim
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
