Rear mounted Grader Blade on Pickup/SUV - Ford Truck Enthusiasts Forums
Old 04-16-2006, 08:54 AM
Richard2212 Richard2212 is offline
Richard2212 is starting off with a positive reputation.
Anyone know of a way to use a 3 point Hitch grader Blade on the rear of an SUV or Pickup?? I want to grade my driveway and clear snow.
Thanks, Richard
Old 04-20-2006, 09:42 PM
To All- I made my own and it works fine. I now will make them and sell them on ebay.
Old 04-22-2006, 07:29 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
You might want to check what is available at www.northerntools.com. Most farm stores sell cheap adapters for 2" receivers for about $50.00.
Old 04-22-2006, 07:47 AM
Quote:
I am talking about adapting a 3 point hitch to my Excursion. Are you talking about a standard ball adapter?
Old 04-22-2006, 07:18 PM
That and the more expensive ones northern sells. Just go to northern and type in "3 point" and sort from more expensive to least.
Old 04-22-2006, 07:56 PM
The adapter I asked about originally is the reverse of the Northern 3 point adapter. The Northern unit puts a 2 " receiver on the back of a tractor that has a 3 point hitch mounting.
The adapter I want is mount a 3 point hitch grader blade on the rear of my Excursion. I have since made one - use it on my driveway and now offer similar units on ebay. Please look at ebay #7612644241 and you will better understand what I talking about.
Old 05-07-2006, 09:57 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
That looks cool, but how well does it work? I think it'd be a PITA to get in and out everytime you wanted to raise and lower the blade
Old 05-08-2006, 04:25 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Maybe you could make a short video of it in use. I have a tractor but it looks like it would work. Hats off to you for actually engineering something you needed.
Old 05-08-2006, 07:28 PM
Hey, very cool! That last picture explains it the best, I hope you sell a ton of them :-)
I understand the manual part, if you are grading a long driveway, you only need to get out once, when you want to turn around, so no real need for a power up/down.
May chat/BS thread cookie88 Arkansas Chapter 62 05-27-2015 09:55 PM
Indicator stalk elec problem richard9591 1968-2013 Full Size Vans 2 03-27-2015 04:53 AM
Snow plow stranded 94 f350 460 Alta 1987 - 1996 F150 & Larger F-Series Trucks 14 03-27-2011 08:48 PM
"Another Ford pickup or SUV burns up!" sailoredon General Automotive Discussion 26 08-17-2005 04:47 PM
Galion Pull Behind Road Grader Dayton General NON-Automotive Conversation 6 10-16-2003 08:06 PM
Tags
3pt, backblade, blade, build, find, ford, grader, grading, hitch, mounted, pickup, point, rear, reciever, suv, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
