new exhaust noise
new exhaust noise
I installed a new 4" exhaust (turbo back) a couple weeks ago. From The first time I started it, to now, it makes this high-pitched whine immediately after start up. Actually it sounds more like a jet engine. It only lasts about 5-10 seconds though. And there are no leaks. BTW, I deleted the cat.
It sounds like the turbo. Is it because the turbo isn't so restricted now? I'm puzzled.
"immediately after startup" - do you mean after ignition but still at idle or after you start driving? Also, is it a roar type noise or a high pitched whirring? A roar would indicate possibly the EBPV if your air temps are quite low - typically below 30 or so. A whirr would be the turbo. With a cat delete 4" dp and exhuast you will hear the turbo a lot. With stock dp and exhaust you will not likely hear it at all so now you discover new noises.
the EBPV is a butterfly valve that closes when the air temp gets to a low point so that the engine will warm up faster. From my experience the time difference is immeasurably small. I disconnected mine at the 2 prong plug at the base of the turbo on the driver's side 2 years ago and have never had any problem since. Unless your air temps at startup are pretty cold it should not activate. If your temps are higher than roughly 30 either the sensor is defective and it is activating or you are hearing something else. You didnt answer my question in the earlier post so I cant be sure at this point.
Well, Thanks for the info and...
"immediately after startup", means, " immediately after startup". Not, after I start driving. I guess the sound is more of a roar, but it also sounds like there's bb's going through it. It's just something I've never heard before, and if most of the guys that posted agree it's the ebpv, then it probably is. Thanks again for the "how it works" blurb.
F 250 6 liter
05-29-2010 07:14 PM
Leonard Bode
20
04-01-2004 09:08 PM
