Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-13-2006, 12:04 AM
bio-d bio-d is offline
Garage is empty, add now
bio-d is starting off with a positive reputation.
Question using stock front tank for svo?
Can I use the front tank of my 87 6.9 idi for svo? Greasel has a kit, but Plant Drive doesn't seem to offer this option.
Thanks, Mike
  #2 (permalink)
Old 04-13-2006, 04:27 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
You could use it sure. Depending on what part of the country your in you may have to add a heated pickup. Our Hotfox would fit the bill. Fits a 2 inch opening. If you are in some part of the country that never sees temps below 50 you could live without the heated pickup.
Our basisc kit Comes with..
Vegtherm Mega, 6-port motor drive
fuel selector valve, "forgot-to-purge" buzzer,
Vormax filter and some difficult-to-find-locally
Vormax fittings, instructions, parts list, and sticker are included. $799
Or with the Hotfox
Vegtherm Mega, 6-port motor drive fuel
Vormax fittings, Hotfox, instructions, parts list,
and sticker, are included. $999.00
Do more research before you buy anything. Charle's kits in our opinion need more heat to safely run WVO.
  #3 (permalink)
Old 04-13-2006, 11:16 AM
Thanks Erick,
I live in Northern California and spend a lot of time camping overnight in the snow. The Hotfox sounds like the way to go. I assume I'll have to pull the tank to install it? Will the selector valve replace the stock F/R selector switch or be wired to it? Don't you also have a low amp draw overnight heater? Where does that install?
Thanks again, Mike
  #4 (permalink)
Old 04-13-2006, 12:40 PM
Good point you would not even need the Selector valve. Not sure we sell a kit without the valve. I'd have to ask Craig. You you could just take it as a spare.
We do have what's called our Overnighter(tm). It works with the Vormax. Since I got that my switch over times have been much shorter through the last few weeks of Feb and all through March. At 21F my filter was 47F nice and warm for the oil to flow.
As for dropping the tank yes that would be the easiest way.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
