Hissing sound on hills under load?
96 F250, 4x4, 5.8L, Auto OD, 8800GVW, 340 gears, 3" exhaust, Rad fan delete(2X Flex-a-lite Fan kit #295). Bigger tires, slightly under geared.
I got a strange hissing noise when i'm towing my trailer and it comes and go's.
Its definately coming from the engine compartment.
This only happens when the truck is under load and I lose ALOT of power, usually need to downshift to 2nd to keep up to 80KPH on hills nevermind 100KPH speed limit.
Really feels like the timing is being retarded, or the computer is going into safe mode.
The truck shows no codes in the computer. Strange thing is the truck does have alot of power, just not when I tow my 7000lbs travel trailer.
Anyone have any ideas?
Should I chip the truck, if this will fix it?
with 3.55 gears and 33's I was effectively running a 3.01:1 ration in my axle. Towing a 3 quads and 2 dirtbikes and all my camping gear and gas put me in first gear towing up hills....UGHHH!!! I could barely make 40mph.... with a bad trans. So I think thats gonna be most of your problem, and A chip will help but the first thing I would do is fix that axle. Thats the most highly neglected part of the truck when people put bigger tires on they never change the gears.
Check the vaccume hoses on the manifold there might be a disconnected hose. None the less your power loss isnt due to hissing its due to your gears flat out. The hissing may annoy you but its not causing your loss in towing power. I had a line on the top of my manifold that was in the wrong spot and it made a nice whine.....until I plugged it where it was supposed to go.
Let me stress that the loss in power has nothing to do with the hiss...I have the same loss when I was running the 3.55's it was like no matter how hard I floored it I didnt have enough power and it just redlined in first gear. It seemed like a total loss of power but it was the mechanical disadvantage, think about it 3.00 gears thats highway....you cant pull crap with that.
A hissing noise develops under increased load stress accompanied by a drastic power loss? I would seriously seek out where your vacume leak is. And yes, a serious vacume leak can cause you to lose power. I would also watch your temp when the hissing develops. Just out of curisosity, what weight is that trailer your tugging around with 340's?
Originally Posted by desertdave55
Does the power loss coincide with the hissing? In other words, when you don't hear the hissing is the power normal?
If this was a vacuum leak it would always remain. No?
The trailer weighs in at 7000Lbs, its a twin axle 2005 27 foot travel trailer.(not a light model)
Originally Posted by EgoMan
When does it go away? when the grade flattens out or it just goes away? Im pretty sure mine did the same thing up hills and it was just a dog. Pulled fine on straits but up hill it was like I was dragging a battle ship.
I will look into that fuel pressure regulator, if that might be a cause of the hissing sound.
My truck is lousy on gas too, might have something to do with it.
