Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-11-2006, 07:47 PM
eetmyshourts's Avatar
eetmyshourts eetmyshourts is offline
Garage is empty, add now
eetmyshourts is starting off with a positive reputation.
55 gallon drums?
hey fellas, i was wondering where you guys would suggest to look for 55 gallon drums. i want to use one as a reactor vessel and one as a wash tank but dont necessarrily need new ones. any old used drum should do. i just want to know where to look to find them.
thanks
-aj
  #2 (permalink)
Old 04-11-2006, 09:46 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by eetmyshourts
hey fellas, i was wondering where you guys would suggest to look for 55 gallon drums. i just want to know where to look to find them.
thanks
-aj
They are not as scarce as they were a few years ago. Used to be they would put a $15-$25 deposit on used drums. They would then take 'em back to the refinery to clean up and reuse. Now I guess it's easier to just make a new drum then to use precious fuel to haul back the empties, clean up the drums and reuse them. There's a certain Ford dealer that I know of that usually has 3-5 of them sitting back behind in the scrap metal pile waiting for the iron man to come pick them up. ;-)
You might try a Ford dealer, a speedy lube place or similar places. Talk to the person in charge to see of they have any that you can take off their hands. They might want a couple of buck for them but that's cheaper than they used to be.
  #3 (permalink)
Old 04-12-2006, 01:29 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
if you have any farmer coops in your area check with them, the one around here had 30 or 40 drums of different sizes ranging from 15 to 55 gallon.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #4 (permalink)
Old 04-12-2006, 04:15 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Car washes also are a good source
  #5 (permalink)
Old 04-12-2006, 09:26 AM
thanks for the replies guys, i'll be sure to check out those spots
  #6 (permalink)
Old 04-12-2006, 09:33 AM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud ofckal704 has much to be proud of
If you are in Dairy Farm country, check with any local farmer. They should have 15 to 55 gallon plastic opaque barrels that contained the various cleaning agents used to wash milk pipelines.
Or check the local dairy supplier, they often have stacks of returned barrels and need to get rid of them anyway.
__________________
Kal
97 250 PSD Ex Cab Sd 4X4 ZF5 185k
Buncha low budget mods
"I tried being reasonable. I didn't like it."
  #7 (permalink)
Old 04-14-2006, 11:01 PM
miker67's Avatar
miker67 miker67 is offline
miker67 has a good reputation on FTE.miker67 has a good reputation on FTE.
Too bad you are not closer to Louisiana, we have massive amounts of drums here. We crush probably a dozen a week. Heck, since the storms you can see them piled up on the side of the road.
  #8 (permalink)
Old 04-15-2006, 08:09 AM
yeah here in yuppie ville as i like to call it lol. its hard to find alot of things like simple 55 gallon drums and what not. just gotta look a little harder is all. i'll find some tho
  #9 (permalink)
Old 04-16-2006, 11:28 PM
bassproguy07 bassproguy07 is offline
bassproguy07 is starting off with a positive reputation.
go to your neighborhood quicklube, they dont usually have 55 gals but they have a lot of 15 gal. we pick a bunch of them up and make trash cans out of em and we use them for clean and dirty rags.
__________________
1983 F-250, 6.9 XLT REAL P.O.S!
  #10 (permalink)
Old 04-18-2006, 05:54 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Uhh I picked up the blue plastics at the local feed store for 15 bucks. I also can get large plastic totes from 225 gal to 330 gal for about 110 bucks. I have 2 330 gal and many a barrels. The totes come with a valve on the bottom, built in pallets and a safty cage around them. You should be able to find the same at any chemical supply store.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #11 (permalink)
Old 04-23-2006, 10:35 AM
93-331-29PSI 93-331-29PSI is offline
93-331-29PSI is starting off with a positive reputation.
I have a local drum company, in Norfolk Va, that sells plastic/steel drums for 15-30 each new depending on the configuration (sealed lid/removable). Here is a link to companies that deal in them.
http://www.recyclingmarkets.net/mark...tml?mat=FD&us=
  #12 (permalink)
Old 04-25-2006, 12:19 PM
blhfla blhfla is offline
blhfla is starting off with a positive reputation.
Here in St. Pete (FL) there is a pharmaceutical company that gets a lot of supplies (like glycerin) in 55 gals (steel, plastic). They bind them together when empty for pickup eventually. Sometimes they may have several dozen. I can take as many as I want. See if you have a pharmaceutical or cosmetic manufacturer nearby. Also like Leskwvo said, car washes are good too.
__________________
UNFORTUNATELY, SOLD:
97 F-Superduty(450) 7.3 Manual DRW with 3000lb. liftgate, 141k
99 F250 Lariat SD SC LB SRW 4X4 7.3 Auto -
AFE CAI II, wastegate disable
Tags
55, county, drums, empty, gallon, lancaster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
