oil filter adapter
oil filter adapter
I need an oil filter adapter, after modifying my truck, new front end, power steering power brakes so and on, it seems that even with the shortest of filters on, it's still hits the steering box. So I need to relocate filter how do I get the right parts to do this? I have a 1964 f100 with a 292 I also have headers on it this kinda ads to the complications. What do you guys suggest? Thanks
Here are a couple of links to look at:
http://www.speedwaymotors.com/Search...itleDescr=True
http://www.haydenauto.com/accessories.htm
I have one of the Hayden universal models. You will need to decide where to mount the filter, and how you want to run the hoses between the bypass (mounted on block), and the filter, and how long the hoses will need to be. Hoses usually are purchased separately. Make sure they are rated for pressure and temperature.
Here is a shot of the Hayden mounting on my cab:
http://www.fordcustoms.com/photopost...oto=39&cat=501
I ordered it at Autozone, cost of $47 less hoses. Now in process of changing fittings to aluminum -8AN.
Edit: Checked the links and for some reason unknown they are not working.
Search on the Speedway Motors and Hayden Automotive sites. Think the picture is in my gallery.
whiskey runner
02-10-2016 02:52 PM
rustyruststang50
12-17-2014 12:34 PM
khadma
Oil & Lubrication
02-24-2008 09:27 PM
bob-63-292
05-22-2003 07:56 AM
