WVO filtering
Old 06-03-2006, 04:46 PM
willbd's Avatar
willbd
willbd is offline
Question WVO filtering
Has anyone tried adding salt to WVO?
I did a test on some crappy looking WVO. I added some water softener salt and let it sit over night. All the crap is now on the bottom and the oil looks great.
The question is does the salt stay in the crap or is there some salt in the WVO.
Old 06-03-2006, 07:09 PM
jimkidd's Avatar
jimkidd
jimkidd is offline
You could probably wash the oil and get the salt out. If there's anymore added by your process. I would think WVO would be full of salt and other crap disolved into it.
jimbo
Old 06-03-2006, 08:38 PM
bhiggins's Avatar
bhiggins
bhiggins is offline
why not just heat the oil up and let it cool back down and the crap and water will settle to the bottom
HIggins
Old 06-03-2006, 08:45 PM
willbd's Avatar
willbd
willbd is offline
I tested this on WVO that would not clear up with heat. The issue was not the water but the large amount of small particles that hold the water.
After I added the salt and let sit for 20 hours the all the small particles were on the bottom and the oil was clear.
Old 06-13-2006, 09:00 AM
Hotwheelbill's Avatar
Hotwheelbill
Hotwheelbill is offline
I am working on my first 55 gal. drum of WVO that I filtered with 15 micron and moved it to a 55 gal. drum with some salt and baking soda. I plan to let that sit for some time....weeks, then filter 1 micron to final drum and heat, cool, pump from top leaving bottom 1/3.
I have read on Greasecar site that the salt and bs do work.
Old 06-13-2006, 10:31 AM
willbd's Avatar
willbd
willbd is offline
How much salt and backing soda do you use?
Old 06-13-2006, 11:03 AM
Hotwheelbill
I used 2 cups of water softner salt and one half cup of BS and mix.
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
Pocket
02-14-2009 04:17 PM
Orpackrat
10-14-2006 12:03 AM
leskwvo
12-10-2005 09:47 AM
onioncasserole
11-03-2005 08:51 AM
Quick Reply: WVO filtering
