Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-10-2006, 11:52 PM
shipfitter1966 is starting off with a positive reputation.
Timing Cover Oil Seal
Anyone know where I can find a timing cover oil seal for a 292 Y ...
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-11-2006, 01:44 AM
Homespun91's Avatar
Homespun91 is starting off with a positive reputation.
NAPA carries them as just the seal, or with the front cover kit.
__________________
IN: Staring adversity in the face while working on your car and coming out on top
OUT: Finally realizing that every $%&# thing you touch on your car turns to adversity
  #3 (permalink)
Old 04-11-2006, 01:05 PM
46yblock is starting off with a positive reputation.
Shipfitter,
I may have an extra new one. If so I can just mail it to you, assuming you can wait that long. No charge, except if you have an extra, would trade a thermostat housing gasket. If no gasket, no problem. Mike
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #4 (permalink)
Old 04-11-2006, 08:38 PM
I spoke too soon Shipfitter. Looked through the gaskets and such and there wasnt a seal.
At least I unexpectedly found an oil pan gasket!
__________________
1990 Ranger 4WD
  #5 (permalink)
Old 04-13-2006, 08:19 PM
Thanks, found one at Napa............
  #6 (permalink)
Old 04-14-2006, 10:25 PM
buns's Avatar
buns is starting off with a positive reputation.
Quote:
When you get to putting the new seal in just remember, the timing chain cover has no dowel pins to center the seal on the crankshaft snout. The best you can do (without the special tool that the factory had) is to eyeball the seal where it goes around the snout. The weight of the housing will always try to pull it down. Hope this helps.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
