Fuel Heater for VVO
Originally Posted by MobeyDick
Does anyone know of a Fuel heating system for a 01, 05 & 06. I plan on running B50 all summer but next winter that may be a bit much. It don't get real cold down in South GA.. Next year I would like to run SVO-VVO all year!!
Fab should be able to confirm this.
well then you'd want to convert the vehicle. We have kits for 2nd gen 7.3s and 6.0 PSDs.
Take a look at www.plantdrive.com.
Originally Posted by leskwvo
Running B50 probably will not need heat any time of the year down in GA. I think you'd be good to about 20F or so before you'd need any sort of heat. But then you could always run like B20 or something in the real cold week or two you get.
I built a couple of heaters on our big rigs just to help pre-heat the bio. I took a 3/8" steel tee and used a glow plug in the tee side and run the fuel through the straight side. I put it just before the IP, seems to work just fine.
FABMANDELUX.
Brenda Lamka
20
12-16-2016 04:18 PM
mackdog
06-14-2006 08:00 AM
