Steering Columns
Steering Columns
Can anyone tell me if all 48-52 F Series steering columns are the same? I have been told both yes and no. I would like to use a 49 F6 in a 52 F1 if it will bolt in with no problems. Thanks for your help. Also, if someone can explain to me in plain english how to open private messages that would be cool. I guess I am too thick to understand the info provided by the site.
thanks,
fifty2f1
george
s.dak
thanks,
fifty2f1
george
s.dak
Originally Posted by mtflat
I've always heard the F1 - F3 used the same Gemmer 3 steering box. F6 would have been something much more heavy duty. Even if the overall length is the same you'll be fabbing something for the pitman arm and drag link connection as your sector shaft will be larger.
Thanks a lot mtflat...Very helpful.
fifty2f1
Mtflat; you mean that the sector shaft would be larger on the F6 box not on the F-3 box?? if the f1 & f3 are the same? if I follow you correctly?
Thanks
Josh
Edit:
sorry I guess I didn't search long enough!!1
looks like the concensus is that the f1- f3 are the same duh.....
https://www.ford-trucks.com/forums/7...ering-box.html
https://www.ford-trucks.com/forums/6...ering-box.html
thanks everyone for already having the info I needed out there. I love this place!!!
The shaft from the steering wheel down to the top of the box is the same from F-1 to F-6. It is the worm gear on the bottom of the shaft that is different on the F-1 than all the others. The gear ratio on the F-2/F-6 boxes is much slower than an F-1 box. It was popular in the old days to use F-2 and up boxes on a half ton because it gave the illusion of "power steering" on the smaller truck. Tom
It is the worm gear on the bottom of the shaft that is different on the F1 than all the others.
For many years, I rebuilt dozens of these gearboxes, and sold 100's of these parts to customers and Ford obsolete parts dealers when the parts were still available from Ford.
7HC-3524 .. Steering Shaft & Worm Assy / Fits: 1948/F2 F1/F2/F3.
7RT-3524-B .. Steering Shaft & Worm Assy / Fits: 1948/52 F4/F5/F6.
7RC-3524 .. Sector Shaft / Fits: 1948/52 F1/F2/F3.
7RT-3575 .. Sector Shaft / Fits: 1948/52 F4/F5/F6.
Ford part number source: 1948/56 Ford Truck Parts Catalog / Text / Section 35, Pages 131 & 132.
Wellll......., I got the breaking points wrong but basicly what I said was true. I've seen the big truck steering colums with very minor modification used on the smaller trucks a number of times to get the softer gear ratio. The shaft diameter and steering wheel splines are the same up to F-6. Tom
