The front brakes are sticking on my 97 f150. I had the claipers replaced the rotors have been replace. I'm not sure where else to look for sure. Do these still use a modulator valve or is this done by the abs? I think the truck has abs.
The right side is now. But I think the left was before I changed the rotors and calipers. The rotor on the left side was gone and the brake pad on the inside was bare metal.
No wires, they would be in a small harness, then no ABS. You changed both calipers and bled them? Maybe a brake hose is internally colapsed preventing the pistons from retracting?? It's pulling to the right?
