Garmin - Ford Truck Enthusiasts Forums
Garmin
Old 04-07-2006, 07:03 PM
Medic 66's Avatar
Medic 66 Medic 66 is offline
Medic 66 is gaining momentum as a positive member of FTE.
Garmin
Anyone have any experience with the Garmin GPS II+(Plus)? I have an accessory cable that goes from the same place as the power connector back to the serial port on my laptop. The unit did not come with any software if their is something to do with the computer, can someone shed some light on my situation?
Thanks,
RC
Old 04-07-2006, 08:28 PM
whowey whowey is offline
whowey is starting off with a positive reputation.
I don't have the II+, but I do have two other Garmin GPS.
Both have the accesory/power cable as one piece.
Garmin offers a piece of software called MapSource. There a couple of different versions of it. It allows you to download different mapsets into your GPS.
Here is a link to the manual for the II+
http://www.garmin.com/products/manua...t=010-00128-00
Old 04-07-2006, 10:42 PM
woogs's Avatar
woogs woogs is offline
woogs is starting off with a positive reputation.
I have the Etrex Legend, and if there is any use for the cable without the Software (Mapsource) I still don't know what it is.
-matt
Old 04-08-2006, 09:53 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
I do not know about that model of GPS, but, usually the plug has four prongs.
2 serial lines for handshaking
The power comes from the computer serial port to power the device and the serial lines are used for data transfer using simple serial line handshaking up to 115 kps, sometimes they use either xmodem crc or ymodem.
Old 04-08-2006, 01:10 PM
Medic 66's Avatar
I appreciate all the info.....I will keep researching.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
