Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 04-07-2006, 01:06 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Thumbs up Injectors are in!!!
This day has turned out to be a good one.
A few days ago my injectors arrived from Beans deisel performance.
I ordered stockers with new, not reconditioned, nozzles and plungers.
I had originally planned to come in this Saturday to install them, but the workload at the shop allowed me to bring the truck in and install them today.
I was planning to take soundbytes of before and after the install but I was way too excited to wait.
11:00 am
I brought the truck in and pulled the valve covers, removed the gaskets and the wiring harness's.
I pulled both rear injectors and let the oil and fuel run down into the cylinder. I thought that just putting a shop towel over the hole would deflect the oil that comes back up through the injector hole. I rolled under the truck and proceeded to turn over the engine by hand and immediatly noticed that the oil came out with enough force to blow the rag out of the way and soak the air conditioner. UGH. (Stuff a ton of rags on top of the air conditioner unit.)
Ok, that hurdle is over; pull the rest of the injectors. Routine job.
The tips of the old injectors didn't appear to be that worn out, but they were sure making a lot of noise during operation.
Remove the oil deflector tubes using a 5mm allen and the 3/8" impact gun.
Install them on the new injectors, leave them a touch loose for the final adjustment later.
Remove all the glow plugs.
Install all the new injectors.
Torque them to 120 inch pounds.
Roll under the truck again and turn over the engine for two complete cycles ( 4 crankshaft revolutions) NO LESS. More if you hear oil spurting out of the glow plug holes.
Position some cardboard over the cylinder heads to deflect any flying oil.
Crank the engine over (no load on the starter with the glow plugs out) to fill the HPOP rail. This requires a couple of minutes total crank times. Don't do it all at once or you'll bake the starter. 30 seconds, go clean up your tools for 5 minutes and then come back and crank for another 30 seconds. Repeat a couple of times.
Remove the cardboard.
Install the glow plugs. I had a full set of Bosch part number 80 033 ( OEM ) glow plugs that I purchaced a couple of weeks ago to install along with the injectors.
Reinstall the valve covers, boost tubes, reconnect whatever sensors, connectors that were removed to gain access.
4:00 PM
I cranked on the starter for about 15 seconds and it fired with a big cloud of smoke.
I am immediatly struck with how much healthier the idle sounds. A deeper tone, more even, not a bit quieter. So crisp, so clean. There is NO SUBSTITUTE for new injector nozzles. Sounds like a BRAND NEW engine.
Driving around it's smooth, quiet, powerful, all the hammering is gone.
And the amount of throttle required to maintain speed is cut in half. I am positive that my lost mileage is coming back.
Underway the engine is so much quieter that I strain to hear the diesel noise over my 5" cannon, all four windows down.
I am completly satisfied with the fruit of my labors, starting with the Hutch mod, and removing the quick connects, the oriface mod to completly remove the air from the fuel rails and now the final addition: putting in the fuel injectors.
Life is good.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #2 (permalink)
Old 04-07-2006, 01:17 AM
mech2161's Avatar
mech2161 mech2161 is offline
Garage is empty, add now
mech2161 is gaining momentum as a positive member of FTE.mech2161 is gaining momentum as a positive member of FTE.
Good deal!
__________________
Kevin
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
  #3 (permalink)
Old 04-07-2006, 01:21 AM
1999 Ford F-550
Kevin you are either up VERY early or VERY late.
__________________
Dan
  #4 (permalink)
Old 04-07-2006, 01:24 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Quote:
Originally Posted by Kwikkordead
Life is good.
Yup! Say it again!
You're just about ready for summer now, aren't you?
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
  #5 (permalink)
Old 04-07-2006, 01:28 AM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 has a very good reputation on FTE.clem1226 has a very good reputation on FTE.clem1226 has a very good reputation on FTE.
Thumbs up
Congrats Kwik, Nothing like the satisfaction of a job well done.
__________________
Steve
"put your purse down and logger up" Steve C Clemenson AKA E RolumTruckem (ECV 62). RIP June 9 1955 to June 16 2011....... miss ya Dad.
  #6 (permalink)
Old 04-07-2006, 07:48 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant futuremueckster has a brilliant future
Roland Mueck
I like your description of the injector replacement process. I copied and saved it for future reference. Thanks for sharing. Good job!
__________________
Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6 (live tuned), AFE II w/ Pete's Cover, GTP38R w/ 1.15, 6.0 Techni-cooler IC, Full Force SS Injectors, Stealth HPOP, Fluidampr, Melling M-208, Walbro FP, mueckster Reg Return & Fuel Bowl delete, 910 Springs, mueckster built 4R100, 4" SS MBRP, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
... From Rock to Rocket-- Thanks to the Brotherhood.
  #7 (permalink)
Old 04-07-2006, 09:57 AM
guzzle92's Avatar
guzzle92 guzzle92 is offline
no leaks here...
2002 Ford F-350
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
Nice write-up Kwik. I'll be saving it for future reference (hopefully in 50K miles or more ) It's good to hear that they made a tremendous difference.
__________________
guzzle
02 F350 4x4 SRW EC LB Lariat
guzzle's Mods & Maintenance Website
If you own a 99-03 7.3 PSD, this is the place to be:
Roadside Help Network
  #8 (permalink)
Old 04-07-2006, 10:23 AM
trakman's Avatar
trakman trakman is offline
trakman is starting off with a positive reputation.
Question How many?
So Kwik....how many miles did you have on the used injectors. Really made that much difference, huh?
__________________
02 F-250 SD SC,S/B,7.3L Diesel 4X4
03 F-250 SD SC,S/B,7.3L Diesel FX4
Sig Edited by FTE
  #9 (permalink)
Old 04-07-2006, 10:32 AM
1999 Ford F-550
69,000 miles. About 55,000 of those were sucking foamy fuel until I did the Hutch and other mods to the fuel delivery system on my truck.
The engine would rock when the fast idle would activate in the morning and sound like it was running on 7 & 1/2 cylinders. Underway it would sound like a rod was trying to knock. It was getting loud enough to make me feather the throttle and drive around at 2500 rpm. At 2000 it was hammer hammer hammer. And the mileage was taking a nose dive.
I haven't had a chance to drive all the air out of the HPOP rails yet. Only got about 15 miles so far. But it is a VAST improvement over what it was doing before. I'm looking forward to vacation next month pulling the trailer.
__________________
Dan
  #10 (permalink)
Old 04-07-2006, 10:38 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Awesome job, Dan! It's great to hear that all went smoothly and they made such a big difference for you truck.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #11 (permalink)
Old 04-07-2006, 10:55 AM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Great info Kwik.. do you need to use any "special" tools to do the job?
__________________
Clint... Early 99, F350, 4X4, Auto, DRW, S-Cab, Gauges, Diablosport 60 HP, OilGuard, Tru-Cool 28K, 5% Biodiesel, Shell Synthetic 5w40, Western Diesel TurboRamAir, MagnaFlow Exhaust, SSHPX, CCV Mod, Fuel Line/Tank Mod., Speed Bleeders, Bilstiens....
  #12 (permalink)
Old 04-07-2006, 11:34 AM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
Nice writeup. Good to hear that injectors can make that much of a difference. I'd expect it to be purring like a little kitten once you've gotten all the air purged out of the HPOP rails. Maybe time for a little evening drive after work today?
__________________
Jeremy
See My Webshots for pics.
  #13 (permalink)
Old 04-07-2006, 11:57 AM
RobertJohn RobertJohn is offline
RobertJohn is starting off with a positive reputation.
Nice work Kwik...
I'm having mine scanned next week to see if my injectors are bad, I'm hoping I don't have to replace them all, it's the $$$$.
I've done a search for the Hutch Mod and can/t find it.
Any ideas on which thread it is ????
__________________
'99 F-250 PSD 4x4 EC 7.3 diesel auto
Bilstien shocks...Kwik filter
upper rad hose
Ranch Hand Brush guard
ELC.. Warn Hubs...SS HPX...6.0 tranny cooler
  #14 (permalink)
Old 04-07-2006, 01:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
I believe this might help.
BTW, congrats KWIKK. Good writeup.
__________________
Mike
2001 Auto Crew Cab 4X4. 38R and Swamps Hybrids. Transgo and diode Tranny. 400HP but not really. 05 front end and stickers makes it faster.
  #15 (permalink)
Old 04-07-2006, 01:27 PM
Batgeek's Avatar
Batgeek Batgeek is offline
Batgeek is starting off with a positive reputation.
I've seen those instuctions before on their site, but could not find the in tank and pre-pump kit listed for sale anywhere on their web site. Is it an over the phone item or have they discontinued it?
Tags
2000, 73, 73l, diesel, f350, harness, injector, injectors, knock, loud, power, reinstalling, replacement, stroke, tone, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
