Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-06-2006, 03:25 PM
1969fordguy 1969fordguy is offline
Garage is empty, add now
1969fordguy is starting off with a positive reputation.
use propane as a power-adder?
In my never ending tinkering and goofing off, I decided that it would be neat to try propane on my 'budget' race car. I have several cars and this one is the beater of the group. It is a '69 mustang with a carburated 302. Not very fast. My plot was to use an old style aircleaner, the kind that seals up and has a squarish air tube coming off of it. The air tube would go to a long intake pipe getting fresh air from outside the engine compartment. Next put a fitting in the side of the aircleaner and run to a propane tank in the trunk. It would be metered with a solinoid to turn it on and off. The flow can be controlled by nitrous nozzels or the size of the fitting. Depends on how much propane to use I guess. No changes are planned for the fuel system.
Before I get slammed for this idea, it is just for fun! This same car is going to get a lethal nitrious dose at the track later this summer...
So will it work? Will it add any power?
__________________
1997 Powerstoke 7.3L Turbo Diesel 4X4
3" to 4" downpipe, 4" stainless exhaust, superchips programmer, boost, pyro, & trans temp gauges, 6637 filter, 203* thermostat
Yes, it does sound good!
  #2 (permalink)
Old 04-06-2006, 06:43 PM
OzFTrucker's Avatar
OzFTrucker OzFTrucker is offline
OzFTrucker is starting off with a positive reputation.
It may add power for a short time before the engine melts down. I won't get all technical but when using nitrous oxide the molecules of n20 break down in the combustion chamber giving up oxygen to help combustion and nitrogen which effectively cools the charge, this is why you use n20 instead of pure oxygen. If you use propane you wouldn't get any cooling benefit and a meltdown would most likely occur, however if you do it please make some video of it, it would be quiet funny to watch but be careful I don't really want to see you blow your head off.
__________________
The right side is the RIGHT side for the steering wheel.
  #3 (permalink)
Old 04-06-2006, 06:47 PM
Rodder41's Avatar
Rodder41 Rodder41 is offline
Rodder41 is starting off with a positive reputation.
Cool , poormans nitrous lol How about injecting either at wot hahaha.
__________________
Chris
  #4 (permalink)
Old 04-07-2006, 07:41 AM
I'll be careful... I have been running a bigblock '69 mustang with a 175 shot of nitrous for a few years now and managed to keep from having any disasters, I guess the propane is another kind of danger though being highly flammable. After thinking about it some perhaps I will use a nitrous plate for the propane.
And pictures will be taken! Video too if anyone is brave enough to film it!
__________________
  #5 (permalink)
Old 04-07-2006, 09:04 AM
Neb86's Avatar
Neb86 Neb86 is offline
Neb86 is starting off with a positive reputation.
This is just my opinion but, I don't think it will work to simply add propane as a power-adder.
In other words, you will be putting fuel on top of fuel and more oxygen will be needed to burn the additional fuel. So, unless you were planning to turbo charge or supercharge, I believe the end result will be an over-rich condition.
  #6 (permalink)
Old 04-07-2006, 09:07 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
it will be a over rich condition and not run right.
  #7 (permalink)
Old 04-07-2006, 09:32 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Isn't propane injection used on diesels? Like was said above, adding a gaseous fuel to the incoming air stream will just displace air that could be burning in the cylinders, hurting volumetric efficiency and causing a rich condition.
__________________
Eric
'87 F150 302 ZF 5 speed 4x2
  #8 (permalink)
Old 04-07-2006, 10:37 AM
I see. It makes sense when someone points out the lack of oxygen. How discouraging...
Yeah the propane injection for diesels was probably what planted the idea in my head, but the systems I have looked at for that purpose add propane as the boost goes up.
I may try it in small amounts anyway, mostly because I have to learn things the hard way...
__________________
Tags
add, adder, power, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
