head gasket 1999 ranger 3.0 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-06-2006, 08:43 AM
Johnny one Johnny one is offline
Johnny one is starting off with a positive reputation.
Is the head gasket job on the 3.0 very difficult? anything special to watch out for? I really want to do the job my self and I really feel I have enough know how with a little help. any info would be appreciated.
Old 04-06-2006, 09:03 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
OK, I'll bite. Nothing special if you have a distributor equipped engine. The intake bolts and probably head bolts are 'torque to yield' which means you get to buy new ones if you want it put together right.
You need special gizmos (cheap) to disconnect the fuel lines, and maybe some coolant lines (heater core).
How did you determine that you need to replace it(them)? The Vulcan may be pokey, but it sure is reliable, IMHO. Got over 200k on mine, and still running good. What symptoms? You may be surprised at how much mechanicin' and diagnosing can be done over the net.
tom
Old 04-06-2006, 08:08 PM
It sure is realiable, It runs great I have 129,000 on it I bought it new in 99 great truck, I have alot of pressure in the cooling system, I have replaced the rad cap the t-stat
drained and back flushed the cooling system, I started it up cold and run about 4 miles the temp gauge went to normal and I had normal heat, then the temp gauge went down to cold and then up to hot and back to normal all in about 1 minute. then it stays normal. after about 15 miles I shut off the engine and the coolent recovery tank is almost to the top. The top hose seems very hard also. The truck has never overheated on me. But I think I have a failure in the EGR system,
Old 04-06-2006, 10:02 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
There are a few comments regarding 3.0L vulcan headgaskets in this article:
http://www.babcox.com/editorial/ar/eb90450.htm
But I also would be hesitant to condemn the headgaskets on your '99, not until you've ruled out everything else.
Old 04-07-2006, 12:58 AM
good article. what else should I be looking at,
2006 6.0 head gasket replacement questions maxum96 6.0L Power Stroke Diesel 7 09-26-2016 10:37 PM
well looks like im going to try a head gasket on my 3.0 anything special I need? mfp4073 Ranger & B-Series 22 06-15-2014 10:35 PM
Headgasket repair on a 3.0L Canoncowgirl Aerostar 7 02-03-2012 07:36 PM
2005 Ranger 3.0L head replacement jdncowboy Ranger & B-Series 2 09-03-2009 01:12 AM
3.0 Flex Fuel heads chiloh30 Ranger & B-Series 1 08-29-2009 08:25 AM
Tags
1999, 30, 30l, brand, cooling, diagnose, ford, gasket, head, hot, ranger, replacement, running, taurus, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
