Air bag warning light code B1884 "PAD warning light failure" cheap fix
I was getting a code that I had an inoperative PAD warning light. I took the Passenger Airbag Disable switch out of the dash and sure enough the bulb was out. Now I had no idea how much that assembly was at the dealer and wasn't about to find out, so I went to my local Rad!@shack and bought a little 5 volt incadesent light with wire leads and soldered it where the old bulb was. I removed the little yellow rubber from the old light and put it on the new light and tada! Code gone and light works for a whopping $1.49. Thought I'd share so hopefully if it happens to someone else they don't have to get bent at the dealer.
mike L
02-27-2016 04:57 AM
EL_Musico
33
10-14-2011 01:32 AM
ehgeeray
06-06-2010 07:34 PM
