Air bag warning light code B1884 "PAD warning light failure" cheap fix
Old 04-05-2006, 09:58 PM
natron037's Avatar
natron037
natron037 is offline
I was getting a code that I had an inoperative PAD warning light. I took the Passenger Airbag Disable switch out of the dash and sure enough the bulb was out. Now I had no idea how much that assembly was at the dealer and wasn't about to find out, so I went to my local Rad!@shack and bought a little 5 volt incadesent light with wire leads and soldered it where the old bulb was. I removed the little yellow rubber from the old light and put it on the new light and tada! Code gone and light works for a whopping $1.49. Thought I'd share so hopefully if it happens to someone else they don't have to get bent at the dealer.
Old 04-05-2006, 11:16 PM
7700Rob's Avatar
7700Rob
7700Rob is offline
Nothing like saving 90 some bucks, is there? Good work. There is a 12V bulb that fits the bill, I forget the #, but if you do a search, it's here somewhere.
Old 04-06-2006, 07:08 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yep.
SEARCH Keywords "LFC 27 Radio shack PAD" and my username....
Congrats on figuring it out on your own.
Steve
rbsev
2017+ Super Duty
08-07-2017 05:27 AM
fish1940
04-18-2017 07:03 AM
mike L
02-27-2016 04:57 AM
EL_Musico
33
10-14-2011 01:32 AM
ehgeeray
06-06-2010 07:34 PM
Quick Reply: Air bag warning light code B1884 "PAD warning light failure" cheap fix
