Go to autozone or advance auto and tell them that you need to get codes pulled, they will go out to your truck with their diagnostic scanner and read your codes and give you a ticket telling you what system is messing up, post codes here and we will direct you to certain problem areas, stuff that needs to be replaced, cleaned, or checked.
