Axle identification - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Axle identification
Old 04-05-2006, 12:31 AM
wolfe1104's Avatar
wolfe1104 wolfe1104 is offline
wolfe1104 is starting off with a positive reputation.
Axle identification
I just bought a 2001 F350 with the 7.3L. I was just wondering if anyone would be able to tell me for sure what axles I have in both the front and the back. Ive heard a bunch of different crap from people about DANA 50, DANA 80s, and the ford 10.25". I figured i could probable figure it out by looking at the vin or crawling under my truck but i havnt really had either the time or motivation. So if anyone could tell me for sure that would be great.
Old 04-05-2006, 10:27 AM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
SRW dana 50 front ford stearling 10.5 rear
DRW dana 60 front dana 80 rear. prob 3.73 ratio
Dick
Old 04-05-2006, 10:35 AM
wolfe1104's Avatar
Hopefully i dont sound to stupid but what does SRW and DRW stand for.
Old 04-05-2006, 10:41 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Those stand for Single Rear Wheel and Dual Rear Wheel.
Old 04-05-2006, 11:01 AM
wolfe1104's Avatar
Thats what i was thinking, thanks.
Old 04-05-2006, 11:27 AM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Quote:
What is your build date? You can find that on the door VIN sticker...
The early 2001 still had the D50 up in the front. However, the late 2001 (very few to boot) had the D60 up front. More than likely you have the D50...but thought I would mention it.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old 04-05-2006, 11:33 AM
wolfe1104's Avatar
Another question that i had was, is how do i tell it the rear is open, couldnt it be limited slip? how do i tell?
Old 04-05-2006, 11:41 AM
biz4two's Avatar
Back to the door VIN sticker. Look at the axle code...and here is a link: http://www.ford-trucks.com/forums/sh...d.php?t=139080
*Plus...here are the codes.
41 3.73 non-limited slip, F-350 (single rear wheels)
D1 3.73 limited slip, F-350 (single rear wheels)
42 4.10 non-limited slip, F-350 (single rear wheels)
D2 4.10 limited slip, F-350 (single rear wheels)
43 4.30 non-limited slip, F-350 (single rear wheels)
D3 4.30 limited slip, F-350 (single rear wheels)
46 4.56 non-limited slip, F-350 (single rear wheels)
D6 4.56 limited slip, F-350 (single rear wheels)
biz
Old 04-05-2006, 12:06 PM
Ya my bad I was dreamin. I thought D60 was in all the DRW from 99. Or I forgot who know's.. Biz4two is right on..
Dick
Old 04-05-2006, 02:26 PM
craziejoker craziejoker is offline
craziejoker is starting off with a positive reputation.
i just have a quick question
had to replace my rear axle seal, so i know exactly what axle i have
it is the stearling
why does my axle have a dana diff cover?
the truck is a 99 psd f350 drw
thanks
Old 04-05-2006, 04:42 PM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.Big Orn has a very good reputation on FTE.
The axle should be a Dana 80, craziejoker, unless someone took a rear axle from an earlier model.
What does the code on the door post read?
Old 04-05-2006, 04:58 PM
theaxle code is 61
i kinda figured that itshould be a dana, but, the seal i bought the firsttime
was for the dana, but it was the wrong one, had to get the stearling one
but, the diff cover clearly has dana stamped in it
the truck is the early 99, that may be the problem, and it is the original axle
(been in family since new in 99)
the dealer couldnt even tell me by the vin and the codes
dont know
Old 04-05-2006, 05:47 PM
biz4two's Avatar
Quote:
Originally Posted by craziejoker
theaxle code is 61
dont know
Here is what you have. It should be a D80...
61 3.73 non-limited slip, F-350 (dual rear wheels)
biz
_______________________________
Old 04-05-2006, 05:59 PM
Big Orn's Avatar
Biz is on top of it again.
Yes, I have a 11/98 build date with the Dana 80.
Old 04-05-2006, 07:24 PM
never mind
Dana 60 and Dana 70 Axle ID Help 78 Ford F150 460 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-15-2016 04:52 PM
Socket for front axles? nickmobile67 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 04-07-2014 06:12 PM
Who can decode my axle tag?? wyazel1 Clutch, Transmission, Differential, Axle & Transfer Case 27 07-07-2012 08:19 PM
Dana 60 question LedheadELH Offroad & 4x4 11 10-24-2006 05:08 PM
Dana 60 rear axle DarkWolf40 Excursion - King of SUVs 16 04-18-2006 03:06 PM
Tags
150, 1976, 373, axle, decoding, end, f350, ford, id, identification, numbers, ranger, ratio, rear, truck, van, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
