Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-04-2006, 11:17 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
an interesting ethanol engine...
Compression fired like a diesel: Scania, another Scania report
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #2 (permalink)
Old 04-05-2006, 01:43 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Garage is empty, add now
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Very nice article!
But I see that:
Quote:
To use the E95 blend in the diesel engine, Scania raised the compression ratio from 18:1 to 28:1, added larger fuel injection nozzles, and altered the injection timing.
Different gaskets and filters are required, as well as larger fuel tanks—the engines burn 65% to 70% more ethanol than diesel.
I guess the fuel economy isn't there but they do have soma amazing pollution reduction figures!
Very good info!
-Thanks
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #3 (permalink)
Old 04-05-2006, 04:52 AM
fellro86's Avatar
1978 Ford F-150
can't quite see ethanol being able to replace diesel or biodiesel, but would be interesting to see them apply it to lighter duty applications. I found another site that explored the small motors with compression ignition and turbo's with ethanol, and at higher rpm's, it came out better. I just can't see it in a heavy duty application though. PDF file: http://www.ifp.fr/IFP/fr/IFP02OGS.nsf/0/A035F6E8F33537C880256F94003B7A09/$file/jeuland1_vol59n6.pdf?openelement
__________________
Tags
engine, ethanol, scania
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
