disc brake conversion kits for my 1971 f-250 camper special - Ford Truck Enthusiasts Forums
Old 11-04-2002, 04:49 PM
powerstroker10 powerstroker10 is offline
powerstroker10 is starting off with a positive reputation.
Post disc brake conversion kits for my 1971 f-250 camper special
I was wondering if anyone knows who makes a disc brake conversion kit for my 1971 ford f-250 camper-special
Old 11-04-2002, 05:48 PM
hawkrod hawkrod is offline
hawkrod is starting off with a positive reputation.
ford.... all the parts from a 73-79 will bolt right on. go to the junkyard and find a donor and get everything. hawkrod
Old 11-04-2002, 06:28 PM
gtex's Avatar
gtex gtex is offline
gtex is gaining momentum as a positive member of FTE.
I thought F250 Camper Specials had disk brakes? What does the Camper Special offer, just the bed side tool box?
Old 11-04-2002, 06:46 PM
jor jor is offline
jor is starting off with a positive reputation.
Old 11-04-2002, 07:06 PM
mk's Avatar
mk mk is offline
mk is starting off with a positive reputation.
The tool box was available on all F-series. The c/s had heavier springs, wiring etc.
Old 11-04-2002, 11:32 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
F250's with the 390 got disc brakes as standard.
Barry
Old 11-04-2002, 11:45 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
I have a 70 F-250 camper special. It has disc brakes, came with a 360. Never could see any special wiring. Springs are beafy.
Old 11-04-2002, 11:54 PM
BB's Avatar
BB BB is offline
There should be a wiring harness under the bed for the camper body interior and exterior lighting. You should be able to see the plug laying on the frame rail (if I remember correctly, it's dark outside).
Barry
Old 02-10-2003, 11:03 PM
mitchell253 mitchell253 is offline
mitchell253 is starting off with a positive reputation.
Question disc brake conversion kits for my 1971 f-250 camper special
I have a 1971 F250 Camper Special 390CI with factory front discs, power steering, and air conditioning. It also has the heavy suspension.
My question concerns the front disc caliper anchor supports which are worn bad enough to cause the calipers to rattle loudly. Drilled them out and inserted steel bushing and wore them out also. Looking at new anchor supports if even available or would it be better to use the tech article and upgrade to newer model disc brakes from 74'-79'?
Thanks
Power Steering Conversion Kit - 1967 F250 Wildcat Fords 1967 - 1972 F-100 & Larger F-Series Trucks 13 05-03-2016 12:27 PM
1971 Ford F-250 Brake issues Herbster454 1967 - 1972 F-100 & Larger F-Series Trucks 12 08-21-2015 04:52 PM
disc brake conversion killbill 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-11-2011 11:40 PM
front disc brake conversion kit JosephPatrick 1961 - 1966 F-100 & Larger F-Series Trucks 21 10-10-2008 10:14 AM
1971 Shop manual flyflinger 1967 - 1972 F-100 & Larger F-Series Trucks 3 08-18-2003 09:27 AM
Tags
1971, brake, conversion, disc, f250, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
