Aux toggle switches in F350 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-04-2006, 09:11 AM
rbelden rbelden is offline
rbelden is starting off with a positive reputation.
Hello there,
Anyone know where I can access the wiring for the 4 aux switches that came with the stock towing package. They currently don't control anything and I'd like to use one for my exterior diesel tank's 12v pump.
Old 04-04-2006, 09:15 AM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
The harness should be on top of your fuse box. Pull the panel off under the steering column then to the left will be main fuse box. Drop the 4 screws and there will be a loose harness. I remember there being a couple orange wires but don't know the configuration of which wire to which switch. If there are any questions do a search. I remember seeing a nice description of the wire colors to each switch. 2 are rated for 10 amps. 2 are rated for 30 amps. good luck. easy access
Old 04-04-2006, 10:19 AM
02PSD4ME's Avatar
02PSD4ME 02PSD4ME is offline
02PSD4ME is starting off with a positive reputation.
- Big panel underneath the steering wheel, comes off by pulling the top away, with those huge big handles made just for the purpose
- Power distrubution panel just to the left with 4 10 mm bolts holding them on.
- Take the 4 10 mill bolts off, pull the PD panel down and away, careful, there's live power here, although protected.
- Look up and to the left you should see the following:
4 "pull thru" wires, red, black, white and blue. These go through the firewall and are "blunt cut" just in front of the drivers side firewall in the engine bay. They're 14 ga, use'em for what you want; they are there so you don't have to go through the firewall with your stuff.
4 upfitter wires, 2 12 or 14 ga, 2 18 ga:
Aux-1 Circuit No 1936 wire color: Orange/Lt. Green [30amp]
Aux-2 Circuit No 1933 wire color: Orange [30amp]
Aux-3 Circuit No 1934 wire color: Orange/Yellow [10amp]
Aux-4 Circuit No 1935 wire color: Orange/Lt. Blue [10amp]
copy and paste
https://www.fleet.ford.com/truckbbas...bb_pdf/160.pdf
Old 04-04-2006, 11:57 AM
thanks to all. very easy install
Thank you for the great info. 15 min and I've run the wire through the grommet in the rear of the cab, under the sill covers and connected to the wiring harness behind the fuse panel. Works like a charm. Wish everything in life could be that smooth!
Aux switches & Harness Murphy IRE 1999 to 2016 Super Duty 7 09-20-2016 08:32 AM
Hooking up aux. switch Pockets52 1999 to 2016 Super Duty 2 04-19-2014 11:16 PM
'08 aux switches Justastrokin'08 1999 to 2016 Super Duty 4 04-19-2008 07:40 AM
AUX Switches...Dumb Question? bowhuntertx 1999 to 2016 Super Duty 3 01-31-2008 09:39 PM
Aux switches FORDSDOWNER 1999 to 2016 Super Duty 4 08-24-2007 12:53 PM
Tags
05, 2005, 2006, aux, connecting, duty, f350, ford, power, super, superduty, switch, switches, tacoma, toggle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
