Can O2 sensors start going bad without throwing an engine code? Would the front two sensors make the motor run poorly and the back two make the exhaust sound funny?
I was also thinking of changing the spark plugs sometime soon which might help.
My last truck (a foreign model) had the O2 sensor going bad. Would run for a week or two, throw a code, reset and it would run for a week or two before throwing the code again. But when the sensor started to go bad, the MPG dropped -- a lot.
I replaced my front two O2 sensors at 100k miles (123k currently) and had a dramatic increase in gas mileage.BTW,no codes were present.I think O2 sensors get "lazy" but will not throw a code.
Ya I looked at the front two sensors today, and they dont look easy to replace especially the one on the passenger side. A lift would be nice! If i get some ambition Ill get it done along with the spark plugs.
mine went in my truck.....they also seamed to get lazy.....then throw a code becaue i started to see a gradual drop in MPG then all of a sudden WHAM down to 8 mpg......i normally get 18 so that was a gradual drop to 14 then down to 8 then the codes came......good luck.....the heat makes them a real pain in the A$$ to get off sometimes.....
Ya i really think I want to change the front o2 sensors. Anyone have advice on doin this? The drivers side doesnt look to bad, but the passenger side looks like a PIA!!!!
I know this is and old thread but I wanted to Change mine out too
My truck is at 150000 and want to know where they are located.
any help would be good
