1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F250 Fire Radio Console and Siren Mounting -- Help!!
Old 04-02-2006, 06:11 PM
csharp2a's Avatar
csharp2a
csharp2a is offline
Hi all Firefighters!
I have an F250 SD and I need to mount my radios. I would like to build a custom console for my truck.. I am looking for plans and Ideas that I can use. I have the following equipment to mount.
1. Icom Mobile
2. Alinco Moble
3. Sho-Me Siren Control
4. Galls Street Thunder Light control panel.
5. Secondary light control panel
6. Mobile Scanner
I want to have room for a power inverter and additional gauges. Also want to be able to install subdued lighting systems to light the console.
I have the dual seats with the deep console in the center. The truck is a super cab.
I also need to mount my Sho-Me 30.0215.P00 concealed siren speaker and I have no idea where in the F250 SD that I can put the thing or how to properly mount it.
Here is a link to a pic of the siren speaker. Any help would be greatly appreciated.
http://www.unixnut.com/swps_1889_6404753.jpeg
Thanks for your help
Craig
Milford, Mi Fire Department
Old 04-02-2006, 08:17 PM
richsoucie's Avatar
richsoucie
richsoucie is offline
if you have a gas engine there is plenty of room under the hood on top of the drivers side fender. or there is a ton of room in the front bumper
Old 04-02-2006, 09:59 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
Craig-
Good to see a fellow firefighter on the list. I've done many installs on POVs (including several of my own) as well as apparatus of varying descriptions. I'll do what I can to help.
First, I'm not sure if I would advise building a custom console. You're going to spend a lot of time trying to fabricate something - at least, I would... not my thing. There are several companies out there who construct consoles for vehicles... Havis Shields, Gamber Johnson, Troy, Jotto, and a few others. Personally, my current truck (2005 F350SD 4x4 CC PSD) has a Havis Consolidator 30" console installed, which will contain 3 Kenwood mobiles, 6 Motorola mobiles, a Whelen Cencom, aux switch panel, and a few other toys (still working on the final build... been dragging my feet and spending my time putting radios in other vehicles.) I'd suggest taking a serious look at the above-mentioned companies... you may find what you want without having to custom-fab the console, or at least come up with some ideas for what you want to build.
On the siren speaker, I'd ditch the "sugar scoop"... they're a pain to mount. Look into the Whelen SA314P, which you can easily mount between the grille and the AC condenser. Personally, I run a pair of SA314Ps mounted on my Ranch Hand front end replacement, between the grille and the guard itself.
Feel free to PM me if you want.
Fearsam
30
09-30-2014 11:21 AM
BigGreen7.3swap
09-28-2014 10:13 PM
jforhan
Electrical Systems/Wiring
09-11-2014 06:36 AM
Jbrown8988
12-30-2010 10:58 PM
csharp2a
09-27-2004 06:25 PM
Quick Reply: F250 Fire Radio Console and Siren Mounting -- Help!!
