gear drive timing
Old 04-02-2006, 05:33 PM
hans88's Avatar
hans88
hans88 is offline
gear drive timing
i have a 1997 460 that iam replacing a headgasket on and replacing some other parts. just looking for some info or advice on a gear drive timing set for this engine?
Old 04-02-2006, 05:43 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Why? The expense will never be recovered in increased longevity. Just use the early straight up chain and sprocket set for improved performance and mileage.
Old 04-02-2006, 06:17 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
Bear is right infact I am not sure that a good roller timing chain won't outlast a gear drive setup. They are intended for race applications that don't care about longevity. What is good on a race engine is not neccesarily good on a street engine. Look at it this way my race engine probably has less than 50 miles on it, and I just finished more or less rebuilding it, and and checking everything for proper specs, and thats not uncommon.
Old 04-26-2006, 10:17 PM
hans88's Avatar
hans88
hans88 is offline
I see your point that i dont need it and a chain drive would be fine but i love the whining sound of the gears. iam not totally sure i want to do this yet either. i know you cannot use gear drives in some engines if it has a knock sensor. iam not sure if the EFI 460 has one because i havent looked it up yet. just wondering if anyone has experience or has one in their EFI 460.
mastersergeant
25
03-31-2017 02:50 PM
Trackerrrr
09-29-2014 05:21 PM
mcne
10-12-2010 03:37 PM
GreenDinosaur
05-31-2008 01:11 PM
mcne
11-20-2005 07:08 PM
Quick Reply: gear drive timing
