my explorer failed emissions test - Ford Truck Enthusiasts Forums
Old 04-02-2006, 12:27 PM
ilbigmike ilbigmike is offline
ilbigmike is starting off with a positive reputation.
Question my explorer failed emissions test
They checked the gas cap, it was ok... they went to check the check engine light... it does NOT come on with key on engine off.... they failed it at that point.... I am new to the obd II system and the related systems... any help will be greatly appreciated... my thoughts are blown bulb in cluster, a blown fuse .... by the way it is a 1997 sport with a 4.0 sohc engine with 135000 miles on it..
Old 04-02-2006, 01:02 PM
vloney vloney is offline
vloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant futurevloney has a brilliant future
that one is an exploratory surgery kind of thing. Blown bulb--bought used, bulb removed---power up problem on the pcm---ground problem on pcm
Old 04-02-2006, 08:41 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
Yep.
Replace the bulb--fail bulb check you fail inspection automatically; get codes scanned--why bulb was removed in first place then come back to us with said code numbers so we can help you.
Old 04-16-2006, 12:14 PM
Thumbs up replaced cel bulb....
and two others behind dash.... no problems....other than my shift indicator is not right... it came out a bit when I moved cluster to remove the #74 and 2 #194's behind...but now the cel comes on as it should when you turn the key on,engine off... illinois' emmissions failed me because of this....would not even continue the test to tell me if there were other problems,lol...beaureaucratic bs...at it's best...have driven it about 2 miles since I replaced bulb...no cel on....so ,I guess until I get a obd II tester ...its all good!...thanks for all the input....if it fails again,i will have the autozone or murray's folks pull codes for me....mike
Old 04-23-2006, 01:01 PM
Question pulled the cel..codes...
now i need some help....the codes I got were:
PO442 evap emissions leak (small).....this one I knew... you can hear it...
PO430 cat effiency below peak(bank2).....
I erased the codes and have not seen the light come back on....although it was only a 3 mile ride from the Murrays by my house ...home.....
any input will be helpful......
I will be buying an obdII tester soon... I looked at the one from harbor freight for 39.99 on sale -any good....or should I spend the extra cash and get the better ones to erase codes as well? again any input will be helpful.....thanks ...mike
Overheating Mystery aochoa1783 6.0L Power Stroke Diesel 3 05-09-2016 08:58 PM
STRANGE ISSUE 1998 F-150, 4.2L V6 Starter issues 98F150on33s 1997 - 2003 F150 6 11-26-2014 12:28 PM
Fail Safe Mode? MUD BUGGY 2004 - 2008 F150 3 07-10-2006 06:00 PM
95 (late Year) OBDII "Link Fail" 96ironman Explorer, Sport Trac, Mountaineer & Aviator 5 05-08-2006 06:16 AM
How do you know if your relay fuses are blown lifeztds 1997-2006 Expedition & Navigator 3 06-29-2004 08:45 PM
Tags
150, 1994, 1997, 2002, 2006, 97, emission, emissions, explorer, failed, fails, ford, obd, po430, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
