Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-01-2006, 08:10 PM
Orpackrat Orpackrat is offline
Garage is empty, add now
Orpackrat is starting off with a positive reputation.
Question What types of pipe for WVO?
What types of pipe can be used for WVO and will not have a reaction. I am doing some research on how to use a vehicles exhaust system to preheat WVO. An idea was suggested to me on using a pipe and electric controller to divert exhaust from mid-pipe and reconnect at the end near the outlet. The idea is to have a metal line for the fuel to travel down within this alternate exhaust line. Another method instead of an electronic controller, but with testing a small diameter pipe (yet to be determined) instead of an electric controller. I would like to know what types of metal can be used with WVO without any problems.
Thanks.
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
Converting to run WVO, will also convert to custom flatbed with pop-out 5th-Wheel, thinking about making custom popup camper-tent for it as well.
  #2 (permalink)
Old 04-02-2006, 08:21 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 is gaining momentum as a positive member of FTE.Fullcrew7.3 is gaining momentum as a positive member of FTE.
I was going to ask the same thing. Mind you, specifically copper. I got a slip tank the other day and am now going to set up an egine coolant coil to go inside for warming so I can run bio all winter. Gonna heat the fuel lines as well. Anyway, that's a little different question than packrat's, but along the same lines.
Thanks
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW, DIY 4x4 conversion, 4.10 gears, Sky 3" RSK, DIY 4" exhaust, 3" diamond eye DP, SC 1705, Stage 1 Rosewood sticks, Valair SMF, SD I/C, 37/12.50/16.5 wranglers and some more DIY stuff
  #3 (permalink)
Old 04-02-2006, 09:08 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Thanks
No aluminium or copper, WVO is acidic, steel is ok.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 04-06-2006, 08:08 PM
Kapper44 Kapper44 is offline
Kapper44 is starting off with a positive reputation.
I've been doing a lot of research on converting my '03 PSD to run on WVO. Still trying to decide on which company makes the best conversion kit, but one thing everyone seems to agree on is Steel Fuel Lines. Not only is the WVO acidic, but apparently the copper lines oxidize the WVO and increases the acidity of the WVO going through components causing early failure.
  #5 (permalink)
Old 04-07-2006, 04:32 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
On Plant Drive kits we supply a modified stock line That runs from the HFCM to the engine, both supply and return. The Vegtherm and the other items are pre-attached to this line if you go with the Vegtherm option. This makes the conversion go pretty quick since these lines have the Ford quick disconnect ends.
All other lines are good quality HP rubber fuel lines. In our two tank design the diesel and WVO only share the steel section of line forward of the HFCM and the little secondary filter in the valley of the engine, so rubber is not an issue.
email me we can talk more about the Plant Drive kit
  #6 (permalink)
Old 04-07-2006, 01:20 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
If you mix in 20% Diesel and 5% Gasoline with some cetane boost and filter it really really good, you shouldn't need a conversion kit.
  #7 (permalink)
Old 04-07-2006, 06:11 PM
1935 Ford pickup
Quote:
Horse pucky
__________________
  #8 (permalink)
Old 04-07-2006, 07:04 PM
The last thing you want to do is run a cold engine on WVO. Upper ring land coaking will soon follow. Running unheated WVO will lead to the same effect. There are a many studies that address this very point.
Convert the veggie or convert the vehicle the only two good choices.
  #9 (permalink)
Old 04-08-2006, 09:50 PM
Way2Slo Way2Slo is offline
Way2Slo is starting off with a positive reputation.
Why not just heat the WVO with a heat exchanger or water coil?
Start it on diesel and switch over after warm... (110-125) We actually left it on to long and overheated the rubber? rings around the fuel line and started leaking Diesel. We now have a safety on it and if the oil hits 130 it shuts the pump off.
http://www.lytron.com/custom/exchangers.asp
  #10 (permalink)
Old 04-10-2006, 10:14 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by fabmandelux
Horse pucky
Ditto what Fab said.
Besides they wont stay mixed.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #11 (permalink)
Old 04-14-2006, 11:44 PM
parkland's Avatar
parkland parkland is offline
parkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to beholdparkland is a splendid one to behold
The cool thing about heating the oil from the exhaust, is that you could potentially have more control of the temp, and higher oil temps. Oh yea, no copper!! or galvanized tanks!!
  #12 (permalink)
Old 04-15-2006, 07:32 AM
Could a stainless steel fuel line work for WVO and the orginal secondary fuel tank on the truck?
__________________
1985 F-350 Crew Cab
V8 6.9 Liter
3-Speed Auto
Manual Glow Plugs
Tags
conversions, copper, diesel, diy, duty, ford, fuel, line, lines, metalpipe, pipe, piping, super, types, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
