1989 F250 - how to remove rear brake drum - Ford Truck Enthusiasts Forums
Old 04-01-2006, 03:19 PM
masonma masonma is offline
masonma is starting off with a positive reputation.
I have a 1989 f250; my left rear brake drum will not come off the axel/hub. I have read the Hayes manual and it make a reference that if the axel is heavy duty, then I need to pull the axel out.<O</O
How do I know if I have a heavy duty rear end? The truck is 4x4 with 8 lugs per wheel.
I have rotated the star wheel as much as I can, (the star wheel is shut and need to be replaced). With the rear end in the air the tire removed I can rotate the drum by hand with not brake drag. The drum seems to be frozen to axel hub.
<O
Any help would be appreciated.
<O
Matt
Old 04-01-2006, 05:03 PM
crawdad crawdad is offline
crawdad is starting off with a positive reputation.
Quote:
Originally Posted by masonma
How do I know if I have a heavy duty rear end? The truck is 4x4 with 8 lugs per wheel.Matt
Look at the factory information tag on the door post. If the GVWR is 8600 lbs, then you have the HD model. Course with mine, all you have to do is ride down the road. Jars your teeth out and rides like an old buckboard.
Old 04-01-2006, 05:06 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
BFH, or, Big, ummm, Hammer. Seriously. I wailed on mine with a 22 oz. framing hammer and they wouldn't come off. So I went and got my 4 lb engineer's hammer, gave them a moderate whack and they popped right off. Sounds like you probably have a pretty good groove worn into the drums.
Jason
BTW, if you have a HD rear axle, such as the Sterling 10.25, your GVWR on the door sticker will be around 8800 lbs. Otherwise, it will be something like 7500 lbs. For the Sterling full-float axle, you don't have to take apart the axle to get the drums off.
Old 04-01-2006, 10:39 PM
wickymustang wickymustang is offline
wickymustang is starting off with a positive reputation.
The drum has rust welded itself to the rest of the rear end. As already stated, take a hand maul and give it several good whacks at 12,3,6,9 o'clock positions and it will come off.
Old 04-07-2006, 01:29 PM
gatesj gatesj is offline
gatesj is starting off with a positive reputation.
Or better yet take the oxy/acteylene torch with a big cutting tip or preferrably a heating tip and go around the center of the drum, just outside of where the hub sticks through, and run it around on there. It will usually "crack", sometimes barely something you can hear, sometimes a loud "CRACK" and then all you have to deal with is the shoes being in the groove and holding it on. With heat, remember, you don't run the risk of ruining bearings by beating on things.
Old 04-07-2006, 02:46 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Your axle should be a Sterling 10.25". Like others have said, the axle does not need to come out. Whack it with a hammer until it pops free. And make sure the e-brake is off.
Lost front left drive bearing .... RV-Dean 1999 to 2016 Super Duty 7 02-26-2008 05:38 PM
OK fellas...enlighten me please... lil smokey FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 04-17-2007 08:58 PM
DPFE Sensor/ Self-leveling Questions BullochDawg Expedition & Navigator 11 03-16-2007 02:30 PM
FYI: '90 Bronco II A4LD intermittent transmission overheating or slipping mblalock Bronco II 3 09-04-2006 10:53 PM
Cruise control troubleshooting kgk 1968-2013 Full Size Vans 1 04-05-2006 10:48 AM
Tags
1989, 2003, axle, brake, drum, e250, f250, f350, ford, rear, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
