Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-21-2002, 11:41 PM
Ford_Forever is starting off with a positive reputation.
what brand of plug wires?
hey guys
i'm doing a tune-up on my truck and i was wondering if anybody had any suggestions as to the brand of plug wires to use. i've got a stock 360 that still has points and i just got some autolite platinum to put in. thanks for your help
Chris
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-22-2002, 01:12 AM
Scotty1 is starting off with a positive reputation.
The brand of plug wires you buy for a stock 360 isn't going to help much. If it were me I would buy some good 8mm plug wires form the local parts house and go from there. They come in a multitude of colors so you can get some that look cool too. If you are wnating to help the everyday run ability of your truck you should look into upgrading your ignition. Dump the points ignition and get a pertronix elctronic kit. They can be had at JCwhitney and many other places. Just do a search for pertronix I think that is how it is spelled. The other good thing about it is you don't have to change, clean, or gap your points all the time. You will be glad you did.
Scotty
__________________
By the way FORDS RULE.
F= First
0= On
R= Race
D= Day
  #3 (permalink)
Old 08-22-2002, 08:51 AM
mlf72f250 is starting off with a positive reputation.
I bought a set of Autolite wires from the local parts house about a year ago. They're not exciting, but they're decent, standard, and reliable.
I thought I was being pretty careful, but did manage to cross two. It idled slightly worse and accelerated a lot worse until I uncrossed them. I guess the timeless advice about swapping only one wire at a time still applies.
Several years I was doing some dyno work on a small block Chevy and thought I was doing a great thing by getting some Mallory wires and Moroso looms. They were bright and pretty until the exhausts got warm. They melted like chocolate and I went back to the boring stock HEI set. If I'd had a fan on the engine to keep them cool (like the normal vehicle circulation on the road), those fancy wires may have been ok.
--Matt
__________________
85F250, 460, 4-bbl, 4-speed, stock, standard, reliable -- no hot rod parts for me this time around.
My FTE Website
  #4 (permalink)
Old 08-23-2002, 07:06 PM
1970moose is starting off with a positive reputation.
If you want a good wire that is reliable and has a lifetime warranty, go with Jacobs. They're middle of the road: way better than stock, but not racing wires. They are great. They are completely sealed, so they're ideal for trucks. They're blue too. Jacob's also has a great ignition system called Omni that is good for trucks. The wires are usually around 50 bucks.
Greg
  #5 (permalink)
Old 08-23-2002, 07:55 PM
Mike W's Avatar
Mike W is starting off with a positive reputation.
Change your cap to the two piece type that came out around 1975. This has connectors like the spark plugs, wires will not pop off. Get the spiral wound wires in 8mm. Do not use the stock carbon core type. You may be able to get a life time warrenty. Now you will be all set for a ignition box upgrade,
__________________
FTE: You can check out but you can never leave.
  #6 (permalink)
Old 11-18-2002, 12:25 PM
GolferSA's Avatar
GolferSA is starting off with a positive reputation.
Stock 352, 2bbl... trying to be more fuel efficient, and get better performance. Just picked up the Pertronix Ignitor with high voltage coil... considering the 7mm wires (stock look) and installing Splitfire plugs... what is the best recommendation for a cap and rotor to hold up to the increased spark, or is stock ok?
Open to suggestions, thanks!
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
__________________
GolferSA
  #7 (permalink)
Old 11-18-2002, 01:57 PM
jherman is starting off with a positive reputation.
MSD has the rep for being the best wires around. Go with the bigger diameter. MSD makes a Cap-Adapt for the Ford FE engine with the post type connectors. I run both on my 72 F250 Custom. They fit fine. Haven't gotten around to doing the Petronix points replacement. Do have a MSD 6A box that supposedly will work with the Petronix.
Joe
  #8 (permalink)
Old 11-18-2002, 09:00 PM
GolferSA's Avatar
Excellent article on converting to the big cap and rotor in the tech articles...
http://www.ford-trucks.com/articles/largecap.php
GolferSA
__________________
GolferSA
  #9 (permalink)
Old 11-18-2002, 09:16 PM
Rodder42 is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
