Which transmission fluid to use?
Make sure it's NOT the Mercon V--you want the Mercon/Dexron, sometimes AKA Mercon III/Dexron. Mercon V is for the newer trannies, and could toast your older one.
AOD or E4OD, they both take the same. Don't let someone tell you anything other than what I put above. Type F is no good, either (that's for even older trannies).
Jason
Jason
trans fluid
Go to http://www.autozone.com/servlet/UiBr...=beginShopping
look under Specifications it should be Mecron 3 only not a mixture with Mecron 5
pickncrew
08-26-2010 03:43 PM
