Sweeping gages
Sweeping gages
My 02 F-150 supercrew gages has recently started sweeping at start up. This happens every time no matter when, cold, hot?? It also did a funky idal a few times: raced, shut down, came back on. All gages and radio went crazy!! I checked for a UFO but didn't see one, although my butt did feel a little funny the next day. Anyway, has any of you ever had this problem? The truck problem not the UFO!!
Tim
Tim
Sounds like it's going into diagnostics on its own. This is done by holding in the reset button while starting the truck. Switching levels by pressing the rest button. Sweeping all the guages is the first level of diagnostics. As for what is causing this to happen, good question. Is the reset button stuck in?
The button that I was referring to is the odometer select button that is used to toggle between the trip odometer and the regular odometer. This buttom being stuck was only a guess on my part. What ford390gashog said about a low voltage condition sounds much more likely as the source of your problem.
Originally Posted by ATC Crazy
I had to replace my battery last weekend because it died, and I never got the sweeping guages....
Originally Posted by bigdaddyII
Did it go dead while the truck was sitting? Many vehicles guages sweep when a cell is letting go in the battery, I guess diffirent variables for diffirent vehicles. Every vehicle I have ever heard of where the guages start sweeping upon startup ends up leaving whoever is driving stranded in less than a month. I had an S-dime that started doing that and I thought it looked cool so I didnt think nothing of it, truck started like normal and didnt make any noises so I was good to go. Than the truck wouldnt crank, than 5 minutes it would, I never thought about the battery, it did this for about a week and became worse and worse, finally I opened the hood and saw that the eye on the battery was red, replaced battery, bye bye guage sweeps.
It was the origional Motorcraft battery from 1997 though
redneckgrl88
01-29-2008 08:00 AM
