holy crap.
lol. I don't know where the rest of the picture is. I still don't see how leaving the truck running can have any correlation with the ignition switch after 4 weeks worth of delivering. (and thats only 3 days a week, 5 hours per day.. and i hardly even drive the truck for delivering)
I took the wheels of and the problem seems to have magically fixed itself. Not hanging up anymore, and it was only the drivers side so maybe it was the caliper and not the emergency brake assembly?? This is annoying as no one around here seems to be able to do work correctly anymore, always a problem with it. My brakes feel spongy after the brake job.
Sorry i flipped out on you BillyBob, its just been a long couple of days and the smart alec comment sent me off, my fault i apologize.
if your neutral safety switch gets out of adjustment (it does happen) it wont start unless you jump the solenoid. Your ignition is ok or it wouldnt start at all. nothing wrong with the starter, because it does start. If you drive through water, or live somewhere they use chemicals for snow removal(maryland) emergency brake cables can corrode and hang up. all the problems you have mentioned do happen occasionally.
The key chime seems to be kind of failing too, I don't know if it has anything to do with it. How would i go about fixing the neutral safety switch?
the ignition switch is actually by your knee on the steering column. if i remember, there is 2 screws to loosen and adjust the switch. There also has been issues with the lock cylinder and tumblers hanging up. if you never have been into a steering column, it might pay you to take it to your favorite mechanic. There is a lot of small parts involved
youve got a switch on the side of the trans as well(mlp sensor). from what you say, I think I would suspect the ignition switch or the lock cyl and tumblers "the key chime". The ignition switch does most of the work of the " neutral safety switch". If the lock cyl and tumblers were hanging up, that could be the problem with both the key chime and the starting problem.
Try your spare key, it could be the PATS system not recognizing your key. This would cause it not to crank.
If you just had the brakes done, they could have installed something wrong, but it sounds like you may have a stuck caliper if it has rear disk, or the shoes are adjusted too tight if drums. You didn't say what year or type of truck that you have.
#28
#29
#30
