19.5 Wheel Conversion - Ford Truck Enthusiasts Forums
Old 03-30-2006, 04:37 PM
77f250sc 77f250sc is offline
77f250sc is starting off with a positive reputation.
Has anyone done the Single or Dual rear wheel conversion of putting 225/19.5 rims and tires on in place of the standard wheels and tires on an F-350?
I am curious if the claims of tire life, handling, stability, and drivablity improvments are true. It is an expensive changeover on just hear say. A different truck is in my future and by looking at the tire ratings I may able to get by with a SRW F-350 converted to 19.5's as opposed to going with a DRW F-350. Any real input would be beneficial, thanks.
Old 03-30-2006, 08:32 PM
NEWTEXICAN NEWTEXICAN is offline
NEWTEXICAN is starting off with a positive reputation.
Check out Rickson's.com. You can even see different trucks with different setups. They are pricey and have a backlog of orders.Very nice people.
Old 03-31-2006, 09:05 AM
jmteam6 jmteam6 is offline
jmteam6 is starting off with a positive reputation.
I put 19.5 on my crew cab dually F-350 (1974 model) it cost me about 2000.00 for the complete change over. This was 6 years ago or so and I average about 75,000 to 85,000 per set and the 14 ply rating on them make hauling heavy or towing a dream also when it is empty it is a nightmare of a ride. It bounces at every expansion strip on the road the ride is horrible.
Old 04-01-2006, 11:48 AM
westtntrucker's Avatar
westtntrucker westtntrucker is offline
westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.
Quote:
This is the link for rickson
http://www.ricksontruck.com
Old 04-01-2006, 12:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
One thing I noticed on their website, the tires are rated for big loads, but the wheels are only rated for 3500 pounds at best. I was only looking at the pre 99 Ford wheels though.
What good is a 6000 pound rated tire on a 3000 pound rated wheel?
Old 04-05-2006, 02:55 PM
Truck rating
Without looking at the truck specs, with 6-3500 lb wheels, that is 21000 lbs. GW possible on the truck alone, should still be fine?
I think the main objective is tire life and stability. I can justify the tire cost but the wheels, that's a tough one to explain the neat factor to the bookkeeper aka wife.
Old 04-12-2006, 01:08 PM
Kenneth Brown Kenneth Brown is offline
Kenneth Brown is starting off with a positive reputation.
Its not 6 tires, at most its only 4.
19.5 wheels & Tires on an F350 dually HT32BSX115 1999 to 2016 Super Duty 0 01-21-2014 01:58 PM
19.5 inch wheels and tires for 05 and newer srw f250, f350 drz400dp Ford Truck Parts for Sale 0 12-31-2013 06:29 PM
19.5" wheels for 8-lug x 6.5" bolt pattern? jibronee 1987 - 1996 F150 & Larger F-Series Trucks 24 06-29-2012 08:06 PM
19.5tires be250 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 6 11-12-2011 09:58 PM
1949 F6, 19.5" wheels, what tires? John2Thomas 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-07-2006 06:11 PM
Tags
195, conversion, conversions, dual, f250, f350, ford, hd, rear, rims, tires, truck, upgrade, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
