302 no start - Ford Truck Enthusiasts Forums
302 no start
Old 03-30-2006, 01:42 PM
76cougar74100's Avatar
76cougar74100 76cougar74100 is offline
76cougar74100 is starting off with a positive reputation.
Exclamation 302 no start
i have an 89 5.0L and this morning it will not start. turns over fine getting spark no fuel what sould i doo?
Old 03-30-2006, 07:37 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
The first thing is to check the Inertia switch. A good thump can trigger it and it cuts off the power to the fuel pump(s). In trucks it's usually located on the passenger side of the firewall, inside the cab. Simply push the button on top to reset, if it's already down then that wasn't the problem.
Assuming you have plenty of fuel, next you need to check for fuel pump activation. Take off the gas cap and either (a) listen at the tank while a helper turns the key on which activates the pump for about 2-3 seconds which you can hear or (b) if you have no one available to help, stick a hose into the tank filler (just a little way is fine, not all the way down in the fuel) and listen at the other end of the hose while you turn the key on yourself.
If you're not sure you heard it, turn the key off and then on again. Each time it will cause the pump(s) to run briefly.
If you don't hear the pump, check the fuel pump relay (usually under or around the Power Distribution Box under the hood.)
Check these items and get back to us. If all is good there but you're still not getting fuel, we can give you a few more things to check.
Old 03-30-2006, 11:30 PM
thanx i got one of my mechanics to come over and it turned out to be the connector leading up to the relay some loose wires i have anew connector so ill solder them up
Remote start Fastbird Crossovers 1 02-24-2015 10:51 AM
Wait to start light wanted. finitetime WTB - Parts & other 0 02-08-2015 12:28 PM
1996 f150 starts sometimes jimbomac22 1987 - 1996 F150 & Larger F-Series Trucks 2 09-28-2010 09:38 AM
7.3 diesel hard to start/ Wyoming whadeen New Member Introductions 4 10-08-2008 10:22 PM
No start mikewalsh1 1999 - 2003 7.3L Power Stroke Diesel 2 05-10-2006 06:29 PM
Tags
302, ford, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
