Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #76 (permalink)
Old 02-05-2008, 08:54 PM
Kory Zimmerman Kory Zimmerman is offline
Kory Zimmerman is starting off with a positive reputation.
Quote:
Originally Posted by strokin_it7.3
46637 filter
Wastegate disable
4'' exhaust
chip
CCV
Wicked Wheel
AIH delete plug
Dual relief boost valve/regulator
Sonnax valve/tricumulator springs
SS HPX line
Intank/Prepump mods
gauges
203* Thermostat
What is a Wastegate disable? How is it done and does it help a lot?
Thanks
  #77 (permalink)
Old 02-05-2008, 09:09 PM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
MikeSDK is starting off with a positive reputation.
Quote:
Originally Posted by miller_feed
Ron, you did it again, good post.
Mike, WOW, it ain't that bad is it?
Just sayin', it'd be a lot easier with a handle on the battery....
Maybe I just have fat fingers.......
__________________
Mike
2002 F-350 Lariat CC DRW 4x4 7.3L PSD
Isspro EV A-pillar, AIS intake w/ fender sleeve, MKO 5' exhaust, Tru-Cool Max, BTS VB, B20
  #78 (permalink)
Old 02-05-2008, 09:22 PM
miller_feed's Avatar
miller_feed miller_feed is online now
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
Mike, I have handles on my Mortorcraft batteries. But I have small fingers.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #79 (permalink)
Old 02-05-2008, 09:42 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
I've got some battery straps. Rubber straps with metal hooks on the end that will hook onto a battery and provide you a handle. Check your local golf cart/lawn mower repair shop. They've hooked onto every battery I've tried so far.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #80 (permalink)
Old 02-05-2008, 09:50 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Quote:
Thanks
The stock turbo is designed to build boost quickly for good resposnse and less lag. It has a wastegate to prevent over driving itself which it is capable of. The WG begins to bleed pressure as boost is made and bleeds more and more until defueling is met at about 23psi. Some folks pull the red line off the WG actuator diaghram and plug it onto one of the CAC tubes to get more throttle response.
A non-WG turbo is either that way by design or made that way as it is able to build more boost with less drive pressure. This is usually accomplished with a larger turbine housing and outlet, or a similar drop in unit with a ball bearing center section that can withstand the higher drive pressure.
Some say it is laggy but it has a lot more overall oomph, especially up top where the stocker is trying to self destruct itself.
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #81 (permalink)
Old 02-13-2008, 04:33 PM
spunks00 spunks00 is offline
spunks00 is starting off with a positive reputation.
Hey ron thanks for the great responce, that will be also be a great thing to be able to referance to in the future...thanks again!
__________________
1999 F-350 7.3L PSD CC LB 4X4 SRW 6spd
6637, Leveled, 35's, 4.30LS, (200k miles)
  #82 (permalink)
Old 02-13-2008, 05:17 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of
thanks Spunks.. .glad it helped..i should have put in there, the early 99 was built before 12/7/98...12/8/98 was the start of the 99.5..the front end change was after 2/99 if remember right...
__________________
Early 99 7.3 F350 auto,GTP38R BB turbo, AFE stage2, 5" strait pipe, DP live tuned-PMT1 soon to happen, 140 IDM, Terminator Modified 17* HPOP , DIY fuel bowl delete, DI Regulated Return fuel feeding Ryan Casserly's SS stage 2's moded EPD process 100% over nozzles http://fullforcediesel.com/
exploded view of a 7,3 << more pix of my truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
