Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 01-09-2007, 02:11 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE. ryaneverk2 has a great reputation on FTE.
7.3L oil leak from hpop end plug
http://www.ford-trucks.com/forums/56...look-here.html
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
  #62 (permalink)
Old 03-29-2007, 05:01 AM
ryaneverk2's Avatar
Diagnosing vacuum leak when auto-hubs 4x4 stops working, and heat/AC switches to defrost when it shouldn't:
http://www.ford-trucks.com/forums/59...ped-workn.html
__________________
Ryan Arthur
My Truck Pics
  #63 (permalink)
Old 09-01-2007, 06:49 PM
ryaneverk2's Avatar
Video and sound clips of a stock exhaust straight-piped from Green Dually:
http://www.ford-trucks.com/forums/64...ped-video.html
__________________
Ryan Arthur
My Truck Pics
  #64 (permalink)
Old 09-01-2007, 06:52 PM
ryaneverk2's Avatar
Cheap and quick mods, from bdrummonds: AIH delete with boost tap, underhood mechanical fuel pressure gauge, adjustable map fooler:
http://www.ford-trucks.com/forums/64...cant-wait.html
__________________
Ryan Arthur
My Truck Pics
  #65 (permalink)
Old 09-13-2007, 01:15 PM
zon9 zon9 is offline
zon9 is starting off with a positive reputation.
anyone know if a bad TCC will make a torque converter stick even in reverse
  #66 (permalink)
Old 01-13-2008, 07:03 PM
Xskeezy Xskeezy is offline
Xskeezy is starting off with a positive reputation.
first off anyone have a how to with pics for a programmer install?? bully dog or sct livewire etc.... AND do you have to individually run sensors for egt,rpm or does it display from trucks computer? new to tuners... i already have cold air(6637mod) and no muffler just wanna kick up fuel and get a little better MPG's
thanks again
  #67 (permalink)
Old 01-13-2008, 09:34 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of miller_feed has much to be proud of
Quote:
thanks again
Forget the bully dog and sct. Look around here and you will see that the best chip for our 7.3 is DP-TUNER. Save yourself the anguish of having to do this again, just do the DP.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-VB, DP-TUNER LIVE- stock, HI. 40t, 60t, decel, 80t, 80e, 140s, OBA, 203*, billet housing, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #68 (permalink)
Old 01-13-2008, 09:46 PM
dmueller71's Avatar
dmueller71 dmueller71 is offline
Growing Older But Not Up!
dmueller71 is gaining momentum as a positive member of FTE.
Ditto on the DP. And do yourself a favor. Don't be like me and not get the 140 extreme just to save the $45.00. I've been kicking myself ever since I got it, and even more after I set my buddy up with the DP and he got the 140. Well worth the money. If you're like my buddy, you might have other local guys around you that will tell you that the Bully Dog and such are just as good or better. Show them the way by being the first on your block with a DP. Make the other boys shed a tear.
__________________
Dan
PAA MEMBER#48 01 F250 SD 4x4 SC LB 228,000 05-07 front end facelift and emblems DP Tuner 5" pipes from MKO, Autometer guages on the pillar, Warn Manual hubs, Zoodad Mod, Tru-Cool Max, 6637 KWIKMOD, TRAIN HORNS
  #69 (permalink)
Old 01-13-2008, 10:22 PM
viperbluelx viperbluelx is offline
viperbluelx is starting off with a positive reputation.
Quote:
DP-Tuner sells SCT....
__________________
01 F250 crew cab 4x4 Lariat. Pro-comp leveling kit, DP-tuner 80E and 100hp tunes, ITP overboost annihilator, AFE stage 1, 4" exhaust, HPX line, 315/75/16 Hankook M/T's, Autometer boost, tranny, pyro gauges. 05-up front end, emblems, and mirrors.
  #70 (permalink)
Old 02-05-2008, 01:47 PM
spunks00 spunks00 is offline
spunks00 is starting off with a positive reputation.
Hey can we get a sticky on the turbos? like how the early 99s are smaller, what it takes to convert, why they dont need the WW upgrade, i know some basic but not all the facts to do a good write up/i am looking becasue i think my early 99 turbo is out and i can find regualr 99-03 turbos on craigs list for cheap!
__________________
1999 F-350 7.3L PSD CC LB 4X4 SRW 6spd
6637, Leveled, 35's, 4.30LS, (200k miles)
  #71 (permalink)
Old 02-05-2008, 01:59 PM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
MikeSDK is starting off with a positive reputation.
Batteries
I don't know if this $.02 that I am going to throw out would officially be considered a 'mod', but I'll throw it out there as a suggestion, at least.
When the batteries in your truck need replaced, seriously consider trying to find same-power top-terminal batteries that have a carry handle or strap that make them easy to remove from/install in the truck.
I have beaten my hands to pieces trying to pick the Motorcraft ones up by hand, and have lost a decent mount of blood from scraping sharp edges of fenders, etc.
Seems like most everything I do underhood ends up with one or both battereies having to be removed.
anyhow, just though I'd throw it out there...............
__________________
Mike
2002 F-350 Lariat CC DRW 4x4 7.3L PSD
Isspro EV A-pillar, AIS intake w/ fender sleeve, MKO 5' exhaust, Tru-Cool Max, BTS VB, B20
  #72 (permalink)
Old 02-05-2008, 03:03 PM
jhand124's Avatar
jhand124 jhand124 is offline
jhand124 has a good reputation on FTE. jhand124 has a good reputation on FTE. jhand124 has a good reputation on FTE.
Quote:
How bout a E99 sticky; the turbo is smaller on the compressor side, the stock wheel is the same as the WW, the turbo pedestal is different, the up pipes are different, the spider is smaller and already has the AIH delete, the HPOP is 15* vs 17*, the injectors are smaller 120cc I think, the front rotors are 99mm vs 101mm, the fuel bowl cover is different and has a plastic mounting bracket, there is no foil to delete on the IC pipe, E99 through the SES light very easliy on a chipped truck (*15 HPOP)
Convert turbo=$ if you don't plan on big hp go with the Dominator 66
Click here.
Beans Diesel
I am undecided on turbo upgrade H2E+bigger injectors+Pulse HPOP=big $$$
With the H2E the upgrade kinda comes with the kit (new & different up pipes, pedestal, spider)
Or Dominator 66 & 17* HPOP and Stock 530 hybrids. Less $
D66 is a direct bolt on. Motified stocker to flow more air.
__________________
Jason
E99, F350, 4"ex, AFE II w/ Pete's cover, ISSPRO gauges, TSI built trans, DP Tuner, EBPV brake w/T/C lock & LED. GP LED, True cool max 4739, CCK, S.S. HPX, in cab fuel pressure gauge, FPR shim, Bilsteins, X-code springs, Power Slot cryo rotors & Hawk pads, 244K on the clock. RHN
On work the bench: Intank Pump, Por 15 for oil pan, 140 IDM, .
  #73 (permalink)
Old 02-05-2008, 03:31 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
1%er
2002 Ford F-250
Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of Texas Outlaw has much to be proud of
Duralast Golds have that handle. I have two.
__________________
Scott
'02 F-250 SC SB 7.3L 4x4 w/ 4" SuperLift, 315/75 R16 Toyo Open Country M/Ts, Bilstein 5100s - 6 position DI tuner, AFE Stage II w/Dry S Pro, HPX, 203* Billet, CCV, Sonnax, Tru-Cool, Fumoto, ZooDad, Brite-Box, 4" MagnaFlow SST, ITP OBA, A/C comfort mod!, Autometer Z series gauges, Scan Gauge II, Tough Country bumpers
  #74 (permalink)
Old 02-05-2008, 04:05 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of
Early 99 has a wicked wheel in it from the factory.
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03. But you can put the late99 air cleaner assembly in the early99 truck. The only three aftermarket air filters that work on the early99 are the AFE stage 2, the AIS and the KWIKK 6637.
The early99 track rod has smaller mounting bolts than the late99-03.
The early99 has shallower rotors than the late99-03.
The early99 has shorter hub-bearings than the late99-03.
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round.
The early99 has a different pitman arm than the late99-03.
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
every thing that is painted orange (on the left) are 99.5-03...non painted (on the right)is early 99
the turbo on the left is a 99.5-03 turbo.it has the wicked wheel in it..
these are early 99 plenums. the 99.5-03 plenums are wider, taller and have a 3" hole for the boots..early 99 are 2"
best pic i have for a 99.5-03 plenums... sorry
__________________
Early 99 7.3 F350 auto,GTP38R BB turbo, AFE stage2, 5" strait pipe, DP live tuned-PMT1 soon to happen, 140 IDM, Terminator Modified 17* HPOP , DIY fuel bowl delete, DI Regulated Return fuel feeding Ryan Casserly's SS stage 2's moded EPD process 100% over nozzles http://fullforcediesel.com/
exploded view of a 7,3 << more pix of my truck
  #75 (permalink)
Old 02-05-2008, 08:44 PM
Ron, you did it again, good post.
Mike, WOW, it ain't that bad is it?
__________________
RICK, PAA MEMBER #4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
