Simply amazing! I feel like Ive hit the LOTTO.
Ive lurked here for quite some time and have often wished there was a central locale for the "common mods". Thanks to all responsible.
Would there be a link to reading the realtime data from scanners or programmers? The values or tolerances?
__________________
2001PSD auto CC longbed 4x4,AIS, 305x70x16 Cooper ATs 184,000miles +(at this time)diablo predetor, ccv mod,5 in. cannon,isspro egt and boost,WW, 6.0 tranny cooler for new trans.,thanks FTE
Ford sells a "Window Track Lube" that you can put on the felt in the upper door. I have owned 6 fords in my short life, and every one starting with the passengers window, has gotten slow. I have tried wd40 on the felt, and it works ok for a little while, but it gets on the window. I also tried a teflon stick lube on the window, but the track lube from ford works great. 1 tube will probablly last you a life time.
__________________
Father
Husband
Deputy Fire Chief
Commercial Bushhoging
2006 F350 4x4 DRW
1984 F150 4x4
Part number (4)6637 from http://www.fleetfilter.com
The filterminder can be reused if you fab something up, but not necessary.
The IAT sensor (intake air temp) that was in the stock air box must be reused, and can be simply zip-tied to some brake lines nearby the filter so that it can still get a reading of intake air temps.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more... My Truck Pics
That's obviously been a lot of hard work and hours!
Thanks a LOT for providing that for us.
Pop
__________________ -Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX. Email SpringerPop
1st off...awesome, awesome, awesome!!!! Thank you all for the shoulders to stand on.
Back to the original request…”maybe a list of things that are common upgrades to this engine. Simple to complex, cheap to expensive, benefit vs. cost”fficeffice" />>>
Obviously you guys have NAILED #1) list of things that are common upgrades. I would love if the group could take this a step further and come to a mutual understanding (never use the word agreement) of the rest of the question. I, as a demanding newbee, was hoping for something with the following data fields in a very pretty database format where you could list them by cost or by when you should do them…ahhhh a man can dream!
Task: Wicked Wheel Your Ability: Shade Tree Cost Est: $100 - $200 Benefits: increases air flow, anticipate 5-10% more HP below 1,000 RPM When: 1st year mod Recommend combine with: Tymar aka "kwik filter" aka 6637, 4-5" exhaust Link:http://www.ford-trucks.com/article/...stallation.html
Task:CPS R&R Your Ability: Novice Cost Est: $0-$100 Benefits: You will be stranded on the side of the road if you don’t. When: ASAP Recommend Combine with: N/A Link:http://guzzle.rbmicro.com/cps.html
Theres actually a very simalar thread down in the competition section, called FTE stage one two three etc.
Maybe some of us could post a little down ther, it has potential to be a great section on this forum.
__________________
-Steve
99 F150 XLT S/C 4.6 4x4
99.5 350 PSD 4x4 4r100 xlt 3.73 LS
TS tunes, 6637, 5" cannon, autometers on the pillar
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
