firewall plate
firewall plate
Hello,
I have an 89 7.3 F350 4X4 5 speed. When I push in the clutch I hear a flixing(cracking) noise. I read awhile back about a fire wall plate to make it stronger because of the flex due to the use of the clutch petal. Where will I find it on the truck to see if it has one? Where can I get one if it doesn't?
Thanks,
Thanks,
E8TZ-7K509-A Dash panel reinforcement
<BR>
E3TZ-7K509-B severely damaged Dash panel reinforcement
<BR>
here are the part numbers you need. If you have any flexing you look around booster area and see how bad it is. If there is only a small crack order and install the E8TZ-A kit. If it is a large crack use the E3TZ-B kit.
Ed
<BR>
<BR>
Ed
You are welcome.
Ps does my web page link show up.
www.discountfordpartsaty2kford.com
at bottom of page?
Ed
at bottom of page?
Ed
Originally Posted by tbirdrief
Thank you very much.
Jeff
Jeff
tater_51
03-21-2013 07:45 AM
