Ford 360 / 390 Balance Question
Going by this chart
http://web.ics.purdue.edu/~stanchfi/specs.html
They are internally balanced
FTE has a FE engine forum for these type questions
FE and FT series Ford big block are both internally and externally balanced. All FE engines except the 410 and 428 are internally balanced. FT medium and heavy duty truck engines are externally balanced like their 410/428 FE conterparts. The same can be said for FE and FT series Ford big blocks. Special balancing practices are required if ever you mix parts between the two types. Internally balanced engines don't require the flywheel and balancer be present for balancing. Externally balancer be present for balancing. Externally balanced engines must have the flywheel and balanced and balancer present. When mixing FE and FT parts, all parts must be present for effective dynamic balancing.
The harmonic balancer, aka as the vibration damper, is there to help dynamic balance and dampen combustion pulse shock. Combustion pulse shock hammers the crankshaft with great consistency. The damper or balancer is there to control the vibration or pulsing, which helps increse crankshaft life and smooth out the vibration.
Originally Posted by 73F100*8Mile
how is that possible ericJ when 360/390's are the same engine with just a crank/rod swap?
FE denotes Ford Engine
FT denotes Ford Truck
Erij, your F600 truck engine, would be considered and FT engine and is externally balanced.
The FT engine include 330 cid HD and MD, 359, 361, 389, and 391 cid.
The FE and FT engines are Y-block designs—so-called because the cylinder block casting extends below the crankshaft center line, giving great strength at the cost of weight. In these engines, the casting extends 3.625 in below the crankshaft center, which is more than an inch below the bottom of the crank journals.
All FE and FT engines have a bore spacing (distance between cylinder centers) of 4.63 in, and a deck height (distance from crank center to top of block) of 10.17 in. The main journal (crankshaft bearing) diameter is 2.749 in.
The FE and FT block engines weigh about 650 lbs.
The 410 FE and 428 FE are externally balanced. FT medium and heavy duty truck engines are also externally balanced
If I recall correctly as I have a 391 flywheel in the garage, it would handle a 12" pressure plate and disc. I was going to mill off the counter weight and use it on a 414 build as the flywheel has more mass than a 390 flywheel. Yes the 414 was converted to internal balance. Better to have the motor smooth internally than just the block feeling smooth with external weights. JMO's.
.....=o&o>.....
.....=o&o>.....
