Vibration under acceleration
on
I experience a similar vibration. It caused by the torque converter being "locked" creating a load on the engine at that low of a speed. It will go away as the torque converter "unlocks" during additional throttle or just increasing speed slowly to a higher point. I have the older SCMT and it does this on the tow and hp settings.
on
Originally Posted by empiretc
i think its the t/c. If I accelerate hard, there is no vibration at all. BUt since I usually put around like grandpa, i get it. All I have to do is punch it, and it goes away. I've tried additives but its still there. My buds truck does the same exact thing.
back to the post at hand.
i think you are saying that it vibrates from a stop to 40 mph or so. if that is true i would guess a u-joint is going bad. if they are not obviously loose look for rust bleed around the caps (ie the needles are being ground to dust)
Orezona, the shimming was to get rid of the vibration from a dead stop. I went through that. Took new joints, carrier bearing and homemade shim. If chaindog is getting the vibration from a dead stop and it goes away once he gains some speed, I would guess a u-joint is to blame. Stuck ones usually do that.
tjbeggs and powerstrokedlariat- seems like the more people I ask about that little vibration, the more tell me they have it. Really wonder what is causing it.
