C6 Shifting at 4000 RPM. - Ford Truck Enthusiasts Forums
Old 03-28-2006, 10:37 PM
danlee's Avatar
danlee danlee is offline
danlee has a good reputation on FTE.danlee has a good reputation on FTE.danlee has a good reputation on FTE.
Why does my C6 shift at 4000 RPM when the throttle is open? My motor produces peak torque at 5000 RPM, and peak HP at 6500 RPM.
I would like to have the lower gear until I exceed the peak torque at least.
Old 03-28-2006, 10:44 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
Have you tried adjusting your vacuum modulator? Follow your vacuum line from your intake manifold to the modulator valve on the back of the transmission. Pull the hose off of the modulator valve and you will see an adjustment screw in there. If you turn that in, clockwise, it will raise the rpm at which your tranny shifts. If you back it out, counterclockwise, it will lower your shifting rpm. Assuming you want to raise your shifting point, you would want to turn it in, clockwise. If you have done all of this already, go to your parts store and see what other modulator valves they have. There are a couple different ones out there that should work. Also, if you pull the hose off of the modulator and there is tranny fluid in it, then it needs replaced, it is no good. Hope this helps.
Old 03-28-2006, 10:50 PM
danlee's Avatar
Fatfender,
I'll try to adjust it. I think that it is OK.
BTW, when it shifts from 2nd to 3rd, it breaks the 295R50x15s loose through a 3.25:1 posi 9" rear at 70 mph.
Old 03-28-2006, 10:55 PM
53fatfndr's Avatar
If you have an adjustable modulator, they are designed to be adjusted for your performance engine, nothing wrong with having to adjust them.
Mine breaks the tires too. I have heard this is common when running shift kits, I have a stage-2 shift kit. I have the 285/70x15s with 3.50 gears in a 9 inch We're close on our setups, but I know you have me beat with the horsepower and torque
If you still aren't satisfied, you can go one step further and run a manual/automatic valve body and do your own shifting or let it shift automatic. I have this type of valve body as well.
Old 03-29-2006, 09:47 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
danlee, there are also 3 different modulator valves for the C6. you want the purple stripe. this is the sea level valve . the green stripe is high altitude, and the black stripe is for race cars.
Old 04-02-2006, 11:13 AM
danlee's Avatar
What does a White Stripe indicate?
I adjusted the screw clockwise, it took several turns. I didn't seat it, but it was beginning to stiffen. I'll take it out today and give it a try.
Old 04-02-2006, 01:23 PM
proud_redneck proud_redneck is offline
proud_redneck is starting off with a positive reputation.
i just read your forum, and i am quite interested to see what you came up with, because i have had similar problems with my C6 in my Dually 4X4
Old 04-02-2006, 03:29 PM
danlee's Avatar
I had the truck out, but was not able to get a good run on it so I could determine the shift point. It did feel better.
I'll try it again during the week.
Does anyone know what a White Stripe indicates?
Old 04-02-2006, 07:02 PM
53fatfndr's Avatar
I don't know what the white stripe indicates, but it could be some aftermarket one such as TCI, I'm not really sure. Be careful not to seat the screw all the way in on the adjustment. Seems like I have read where if the transmission is run with it all the way seated it can cause problems. If it seats, I would back it out at least 1/2 to 1 turn. There is quite a bit of adjustability there with these modulators. I was noticing significant changes with just 1/2 turns. Keep us posted.
Old 04-02-2006, 07:33 PM
i have a C6 in my F350 4x4, and i would like to adjust the shift points. does that screw just adjust wat RPM's the tranny shifts at? because i have never heard of that.
Old 02-02-2013, 12:44 PM
BuzzLOL BuzzLOL is offline
BuzzLOL is starting off with a positive reputation.
.. Anybody got any further info to share on this subject/thread? I'm planning to build up the 351M/400 with C6 in my F150... DiMora is already at the C6 point...
Old 02-02-2013, 07:40 PM
danlee's Avatar
I am currently using an E4OD controlled by a Bauman Opti-Shift Controller. The controller is programmable, and lets you select your shift points and line pressure.
360 redline 460jared96 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-15-2015 12:36 AM
Power,Torque, Power Question LIKENIT Modular V10 (6.8l) 39 08-14-2007 10:54 PM
Towing With A Gasser jschira Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 31 11-26-2006 08:38 PM
Redline RPM matthew35 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 10-17-2006 01:07 PM
Best Block for a Torque Monster? Gearjamer Performance & General Engine Building 22 01-19-2004 02:52 PM
Tags
4000, c6, ford, modulator, purple, rpms, shifting, stripe, transmission, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
