Intermittant Switch setup
it will work but takes some work. ford changed the wiring for the windsheild washers on the 80 and newer. the wipers will work fine but you need to check out the two washer wires and ground one of your originals. if you take the plug off the switch you will see one terminal has been eliminated. the wiring on the intermittent harnes still has the wire but it does not connect to anything! good old ford! hawkrod
1968F250LWB
07-25-2003 06:11 PM
1968F250LWB
17
03-01-2003 06:11 PM
1968F250LWB
12-05-2002 08:28 AM
