puller tool for power steering pump pulley - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 06-09-2002, 11:06 AM
hkmp5sd hkmp5sd is offline
hkmp5sd is starting off with a positive reputation.
Post puller tool for power steering pump pulley
I'm ready to replace my power steering pump in my 1992 Ford F150 4.9L six, pick up truck.
I am trying to find out the correct Snap-on puller for this job.
Any help would be appreciated. It seems like a staight forwrd process but any tip for this replacement would be appreciated.
Thanks.
Ray Barnes
Old 06-09-2002, 12:44 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
These type pullers are quite expensive to buy.
You might be able to borrow one from autozone because of their "lend a tool" program.
Other parts place have a tool program also.
Good luck.
*Lisle* makes one that cost $100.00 here in Canada
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTEModerator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old 06-11-2002, 11:49 AM
charlez's Avatar
charlez charlez is offline
charlez is starting off with a positive reputation.
If you aren't going to use it very often you may be better off just buying a cheap one. I got a HarborFreight one for $20 and have used it twice with no problems. If you do get one, make sure it will both pull and then push on the pulley, some brands sell them as two seperate tools.
Old 06-12-2002, 01:11 PM
brokebronco's Avatar
brokebronco brokebronco is offline
brokebronco is gaining momentum as a positive member of FTE.brokebronco is gaining momentum as a positive member of FTE.
go to the snap on website. they are pretty expensive. unless you plan on using it a lot i would either borrow one from a parts store or buy an inexpensive one(also from the same parts store)
Old 06-12-2002, 09:03 PM
Old 10-20-2005, 09:42 PM
gdawghereiam gdawghereiam is offline
gdawghereiam is starting off with a positive reputation.
2 push the pulley back on the shaft,use a bolt screwed in2 the ennd of the shaft with a jam nut on a flat washer.position the pulley and tighten as the washer presses on the pulley.
Old 10-22-2005, 03:07 PM
SDRULES SDRULES is offline
SDRULES is starting off with a positive reputation.
Those pulleys are difficult at best to get off. You can get a pump with a pulley at Auto Zone for not that much more and save the aggravation.
Old 10-22-2005, 03:21 PM
chowitworkz's Avatar
chowitworkz chowitworkz is offline
chowitworkz is starting off with a positive reputation.
For less than professional use I would get a less expensive puller. Also any pump that I have ever replaced always came with a bolt for pushing on the pulley. A pulley is not at all difficult to pull with a proper tool. The difference between the ease of most tasks for the pro or the shade tree mechanic is the quality of his tools.
Old 10-23-2005, 09:28 PM
when u get the p/s pump at autozone,the pump they give u has no pulley.i rented a puller from them.i pulled the pulley and put it on the new pump using the bolt/flatwasher/nut.
Old 10-23-2005, 10:40 PM
They sell the pulley seperate. You just have to ask for it.
Old 11-01-2005, 05:00 PM
afinepoint afinepoint is offline
afinepoint is starting off with a positive reputation.
I agree. Rent don't buy. It is a tool you'll use once in a blue moon. If ever again. When I changed the pump on the Explorer I "rented" the tool from Pep Boys. I left a deposit and when I returned the tool I got the deposit back = FREE. This policy is not uncommon.
Good luck.
Reg
Old 11-02-2005, 10:35 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Quote:
On some vehicles the pulley has to come off to get the pump out of the mounting bracket. Chalk up another one for the geniuses at Ford.
Old 11-02-2005, 11:15 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
I bought a p.s. pump pulley for about $20 at Advance Auto Parts or Autozone (I forget) and it worked well enough on a Chevy with an impact tool. I can't see the Ford being worse.
Old 11-03-2005, 03:58 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I bought the Lisle tool for $47, it also is an installer. Sure is handy to have... if you have a Lincoln or Taurus type engine, you need it to be able to get the ps pump off if servicing the head gasket or such... the Lisle tool is also universal, will work on Ford, GM, and Chrysler for a minimum. Snap On will likely have it as a Blue Point. If you really want Snap on, here is the page: Snap On puller They make you buy a bunch of pieces to do the same thing the Lisle does for less pieces and price. I bought my set from Northern Auto, northernautoparts.com, for $47, item # is 38850. (link was blocked)
Steering wheel puller creedua 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 06-11-2014 01:01 PM
Pulling steering wheel Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 6 03-17-2014 10:01 PM
Power Steering Pulley Tool blageurt 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-19-2014 06:59 PM
Power steering pump pulley bent?.... '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 16 07-11-2011 02:51 PM
Problem removing pitman arm mrdavidkendall Brakes, Steering, Suspension, Tires, & Wheels 5 12-29-2004 05:46 PM
Tags
46, 92, f150, f250, f350, ford, installer, power, pulley, pully, pump, replacing, steering, steeting, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
