heater core leak - Ford Truck Enthusiasts Forums
heater core leak
Old 03-27-2006, 08:08 PM
bohiaa bohiaa is offline
bohiaa is starting off with a positive reputation.
heater core leak
I installed a new heater core " mine was leaking"
Now It seems that I cant get the heater hoses tight enoulf to stop leaking .
I tighten them up and it works fine for a day or two then it starts leaking again
I bought new hose clamps, I'm wondering if I need to take sandpaper and rough up the new outlet's so it will hold better...
Has anyone ever had a problem with this ?
Old 03-27-2006, 09:33 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
I wouldn't go with the sandpaper idea, keep it smooth. I got some questions though.
1.) What kind of heater core did you buy? if it's one of those with the plastic ends then one of them may have cracked
2.) what kind of clamps are you using? If they aren't screw-tighten then take the old spring style off and trhow them away and get the screw-tighten style. If they're the screw-tight kind then tighten them to the point where they are flush with the hose material, providing that the hoses are new. This leads me to the next question.
3.) are your hoses new or the originals. Good idea to replace the hoses when you do this, even if the old ones are ok. The hoses may have conformed to the shape of the old hearter core ends.
4.) where are the clamps located? Make sure that the clamps are past the bump on the ends of the heater core.
5.) how did you get the hoses onto the ends of the heater core? If you pried them on then the hoses may be damaged. Use a little coolent on the inside of the hoses to lube then and help them slip on.
I know that most of this might be a bit insulting, but it's worth checking over. If you've done all of these things then the new heater core may be bad.
Old 03-27-2006, 09:57 PM
no its the type with metal ends...
I didn't replace the hoses, But I did replace the calmps there the screw type
the hoses went on pretty easyly ther had coolant on them so they just slipped on...
But it this dont strighten out I will have to replace the hoses....
thanks
Old 03-30-2006, 11:01 AM
73Custom 73Custom is offline
73Custom is starting off with a positive reputation.
I agree, replace the hoses. As hoses age they get dry and brittle and don't seal very well. Replace them, or every time the weather gets cool, they will start leaking again - been there, done that...
Marty
93 heater core heater hose hook up? LOVEMYLABXS 1987 - 1996 F150 & Larger F-Series Trucks 2 01-02-2015 05:36 PM
replacing heater core in 1994 E150 ttaylor530 1968-2013 Full Size Vans 7 08-25-2011 06:07 AM
heater hose>heater core leak RCM Ranger & B-Series 4 04-28-2010 01:04 PM
Heater hoses Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-23-2009 02:17 PM
4.6 leaking coolant bserrano 1997-2006 Expedition & Navigator 3 10-29-2006 09:46 PM
Tags
64l, core, ford, heater, hose, hoses, leak, powerstroke, ranger, stop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
