New Problem Noticed When Towing. Cough?
  #46
Old 06-20-2006, 02:17 PM
bbranch's Avatar
bbranch
bbranch is offline
I bought an '04 F350 a couple of months ago. First time I had this problem it was towing a lightly loaded trailer up a fairly long but not steep grade. It was very regular with a buck in power and the "cough" every second or so. I also noticed a puff of smoke when it would cough.
I am currently on a family vacation with a 10' camper (no trailer) and at altutides. It seems to be getting worse and I am blowing WAY more smoke then it has before. Does this match with what others are seeing, that it can get worse?
Also, has anyone tried putting in full Banks kits? (replacing turbo or turbo internals as in their more complete kits)? I had good luck with Banks in the past on my '91 didn't figure I needed to upgrade this truck this soon, but I don't like the smoke its blowing and the coughing and loss of power...
  #47
Old 06-20-2006, 02:25 PM
jimth's Avatar
jimth
jimth is offline
This is the same problem I had with my '04 F350. I took it back to dealer and he replaced the turbo. I have not had any more trouble yet...
  #48
BB_TX's Avatar
BB_TX
BB_TX is offline
Same symptoms as I had, cough, shudder, smoke. Try disconnecting your EGR valve and see if it stops. A very easy test. Good pictures and directions in some posts above. Replacing my EGR valve solved my problem. But after reading some of the above posts, I decided to disconnect my EGR valve just to see what would happen. Seems to run better. And I got an immediate 1/2 mpg improvement.
  #49
Old 06-22-2006, 08:00 PM
groots's Avatar
groots
groots is offline
I had the same problem with my 04 F350 Crew Cab. The dealer replaced my turbo and so far it has not happened again.
  #50
Old 06-28-2006, 01:39 PM
jkittre777's Avatar
jkittre777
jkittre777 is offline
Originally Posted by jkittre777
I have a 05 6.0 f-250 4x4. Towing uphill at around 60 and the turbo dumped. Scared the hell out of me and the guy next to me, lol. Next week the engine light came on. Took it to the dealer and they replaced the whole turbo assembly this week. I have not towed with it yet, I will let you know if it happens again.
I towed TT all the way from <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1:City><st1lace>Huntington Beach</st1lace></st1:City> to the <st1lace>Grand Canyon</st1lace> last week and the truck ran perfect. I also noticed that after the computer re-flash that the clutch fan turns on much sooner that before.
  #51
Old 04-25-2012, 12:55 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
resurrecting an oldie
This explains my issue about loaded under throttle turbo cough. However it never happened until installing a powermax. I also just swapped the vgt silenoid, no fix. This thread was years ago so hopefully someone has some input.
  #52
Old 04-25-2012, 01:35 PM
jimth's Avatar
jimth
jimth is offline
I fixed mine by biyi.g a 2011. Do 't hzve any of yhese problems anymore. The other irritating one' was yhe hi pitched squeal under load.
  #53
Old 05-13-2012, 10:55 PM
run6.0run's Avatar
run6.0run
This popping noise is annoying. Only under load. Never, ever did this before the powermax. I've cleaned the ebp sensor and tube, map hose, and replaced the baro sensor, and swapped the vgt silenoid for a new one. No egr n the truck, new air filter. Could the vanes already be sticking? If it wasnt summertime and me finishing my boat remodel, I was gonna buy a stock turbo and see if that fixes it, wonder if I ought to push for a swap out with another powermax.
  #54
Old 05-23-2012, 11:12 AM
jimth's Avatar
jimth
jimth is offline
If it is like a coughing noise replacing the turbo fixed my issue.
  #55
Old 05-23-2012, 03:16 PM
steelhead2's Avatar
steelhead2
steelhead2 is offline
My truck did this to once. Cleaning the turbo fixed it. Whats your boost at when it pops?. My vanes would stick when full boost was applied.
akblackfoot
09-06-2016 04:14 AM
Brucemiller18
04-03-2016 03:32 PM
rews2
03-01-2016 05:25 PM
ajzalesx
09-05-2015 05:13 AM
14psd
09-15-2006 06:53 PM
Quick Reply: New Problem Noticed When Towing. Cough?
