5 audible beeps
5 audible beeps
I drive 1994 F150 5.0 Auto 238000 miles on it
My horn and cruise control has been out for a couple of years.When this happened my air bag light started blinking 3 blinks and 2 blinks.Now the airbag light stopped blinking.When I start my truck I now get 5 audible beeps then it stops and does the same thing total of 5 times in a row then it stops.I also get this sometimes when I step on the brakes going down the road.This just started 3-25-2006 It sounds like a backup signal when it goes off.Can anyone give be any help?
Code 32 = Drivers Side Air Bag Circuit High Resistance or Open
It means your air bag malfunction light bulb has burned out........really.
"From FORD Service CD" If a system fault is present and the air bag indicator is malfunctioning, an audible tone will be heard, indicating that system service is required. The tone is a series of five sets of five beeps. This does not indicate a diagnostic trouble Code 55. If the tone is heard, the air bag indicator is inoperative and a system fault that requires service is present
A device that transfers the commands of the steering wheel buttons to the wiring in the column. It's under the steering wheel.
http://cgi.ebay.com/ebaymotors/Bronc...QQcmdZViewItem
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
Air Bag System Component Location
1. Front air bag sensor and bracket (14B005) -- left-hand side of radiator support (16138).
2. Right front air bag sensor and bracket (14B004) -- right-hand side of radiator support support.
3. Right rear air bag sensor and bracket (14B007) -- right B-pillar.
4. Driver side air bag module (043B13) -- steering wheel (3600).
5. Air bag sliding contact (14A664) -- behind steering wheel.
WARNING
An air bag can cause serious injury, cripple and even kill ! All info supplied is for informational purposes only. Air bag repairs should be left to trained technicians. Please heed this warning!
WARNING
allingeneral
1997-2006 Expedition & Navigator
08-17-2013 03:50 PM
